Old 05-03-2023, 08:25 AM
jocaudron jocaudron is offline
Default PT "Undo" sometimes switches from command Z to command W
I have this very strange behaviour in Pro Tools on Mac (macOS 12.6.3 Monterey).
Normally I can just undo something by using the regular Command Z. But recently I found out that this closes my active window, while Undo became Command W.
I'm using a French AZERTY keyboard (in Belgium) and I suspect the software is sometimes flipping and thinks I have a QWERTY keyboard. The strange thing is that I can still type in the AZERTY way, while that happens.
Anyone any idea what is going on and how I can fix this?
Tnx,
Jo
Old 05-03-2023, 09:14 AM
Default Re: PT "Undo" sometimes switches from command Z to command W
Did you search DUC before posting?
https://duc.avid.com/showthread.php?t=424020
Old 05-04-2023, 04:57 AM
Hi @Darryl, tnx for the reply.
I did indeed search and didn't find anyone with a similar problem. I've checked the keyboard settings and they are correctly put to "follow keyboard layout".
The problem that I seem to have is that sometimes the Command Z works as undo, but sometimes it doesn't and it turns into close active window. As if it switches from US to FR keyboard and back. Very strange.
Jo
Old 05-04-2023, 01:06 PM
Jo
Did you read the part about other users having to...
I have to change "Follow Keyboard Layout" to "Lock to US Layout", then back to "Follow", and it's fixed until next restart of protools.
Does doing that help you?
I do suspect what you are seeing is related to this other known and reported issue, which presumably might be getting fixed soon, but you might also want to file a cast with Avid support, and reference that other issue/case as well.
Old 05-08-2023, 01:52 AM
I am hoping that a future update will resolve the issue. For now, I am utilizing the "undo" button on my NI Komplete keyboard and I intend to set up one of my stream decks as a controller for similar functions.
Tnx!
Old 05-16-2023, 01:10 AM
Originally Posted by RichardBaysinger View Post
have you fixed it?
Not really. I always do the " Follow Keyboard lay-out => change to US => Follow Keyboard lay-out" trick. But that is of course just a work around. Waiting for a real solution, will hopefully be an upgrade of PT that solves it.
Tnx for following up.
Is it possiblt to have turned off the "Undo" command for plugins? PihSant macOS 1 12-06-2017 06:34 AM
12.8 "clip groups with embedded fades not supported for fade command" Sean Russell Pro Tools 12 9 07-17-2017 09:04 AM
preference to DISABLE edit mode command "clutch"/toggle from 12.6 bolooki Pro Tools 12 7 05-25-2017 12:13 AM
Could not complete the Open Session..command Assertion "KeyContextRegistry" line72 JLiRD808 Windows 4 12-25-2012 01:01 PM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
