Old 10-28-2018, 05:36 PM
Tweakhead Tweakhead is offline
Default Re: Changing tempo markers universally?
ok. I think this might fix it.
you probably created your tempo map with Beat Detective originally, right?
I noticed that your tempo markers are blue, rather than green.
well, try this . . .
click on the little plus symbol at the edge of your tempo timeline ruler . . .
does it have "Snap To Bar" checked ? or un-checked ?
whatever it is on, select the opposite. click OK.
do all the tempo markers turn from blue to green?
if so, trimming your tempo events should work now.
fingers crossed !
Old 10-29-2018, 10:02 AM
TWR100 TWR100 is offline
I'm goin to try this latter and I'll update.
I created the tempo map using the tab to transient and identify beat method. I'm sure you are aware of it.
I don't find Beat Detective as useful for tempo mapping.
Old 10-30-2018, 04:57 AM
Great!!!
Once I un-checked Snap To Bar I could then manipulate the tempo markers collectively.
One last question. In your opinion, once I have the correct tempo, should I then re-check the Snap To Bar option? I have no idea how this option (checked or not) will effect the rest of the production.
I guess I could find it in the Reference Guide but usually that offers no practical advise.
Thanks again Tweakhead, I doubt I would ever have worked this out for myself.
Old 10-30-2018, 04:49 PM
yes, mine is usually engaged.
I rarely use Beat Detective either these days. I prefer my own sample accurate ID'ing of points. Once fully mapped, it seems sensible for the tempo changes to be happening dead on the Bar, unless there's a deliberate accelerando etc on beats.
I'm glad this worked out for you. It was an educational process for me too, to track down the cause. The screenshots helped immensely. Well done for your perseverance !
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Tap tempo and involuntary time shifting with tempo changing Skiroy Pro Tools M-Powered (Win) 3 08-26-2010 10:00 AM
Changing tempo in manual tempo mode guentherschmidt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-28-2006 08:52 PM
Changing tempo w/out changing midi performance??? toddm7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2005 10:35 AM
changing tempo without changing midi wizdoom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-20-2004 05:40 AM
