Old 10-02-2017, 05:36 AM
Default Re: I really made a mess of my disk allocation pls help
Originally Posted by lvly5t View Post
It was created and worked off of a USB external drive. That same drive was plugged into my home system and crashing began shortly after. Keep in mind I did not experience crashing at first. I was having to cycle back into session file back ups bc of the issue I first talked about. Initially I thought the session files were corrupted but PT 10 doesn't crash with these at all only 12. Also slight revision the source version of PT was 8 not 9 if that matters.
How about moving the problem session completely on to your system drive and go from there? Take that USB drive out of the picture.
Jack
QAPLA!
Old 10-02-2017, 05:42 AM
lvly5t lvly5t is offline
Just tried it, same issue unfortunately. It's like there is something up with 12 or some particular aspect of 12's protocol that is experiencing errors with the session file backups that 10 doesn't seem to have.
All system info is in my profile
Old 10-02-2017, 05:44 AM
Does a save copy in create copies of the backups as well? Also does a back save create back save versions of the backups? I wonder if it did, if I did a back save then brought into 10 to make a ptx file if 12 would still have issues with it
Old 10-02-2017, 09:48 AM
john1192 john1192 is offline
Save Copy In .. does not save Backups ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
disk allocation help cjac9 Pro Tools M-Powered (Mac) 1 05-31-2007 06:15 PM
Disk Allocation Lucas at Two Fish Pro Tools TDM Systems (Mac) 6 07-06-2006 01:15 PM
Disk Allocation questions and disk error messages 3rdstory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-30-2006 08:10 PM
Disk Allocation Problem -- PT Session can have two disk allocations?? tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-26-2003 07:22 AM
Disk allocation (PT 5.1) stevegalante Pro Tools TDM Systems (Mac) 4 06-05-2001 02:33 AM
