Old 03-21-2017, 10:38 AM
Default AAE Error -20007
Does anyone know anything about this error? My search turned up zip but its popped up twice now. Odd stuff today as my computer restarted itself several times, once with a BSOD that only flashed for a split second. I disconnected everything. Opened the tower, pulled and reseated every card and every stick of RAM, replaced the CMOS battery and reset BIOS settings. Had 12.4 but the App Manager told me I had an update, which I let run and install and now its showing 12.7.1Things that make you go "Hmmmm"
Old 03-21-2017, 11:47 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: AAE Error -20007
Hi did you tried uninstalling everything from Pace ilok ? Then installing it again .
If you didnt , remember to run the utility in the troubleshoot folder ( in pace package) to clear files that are left behind after removing it , just in case .
Lets see if that helps !
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 03-21-2017, 11:56 AM
Will give it a shot
Old 03-21-2017, 12:22 PM
Well that didn't go as planned The uninstall of PACE started, then the PT icon disappeared off the desktop and the uninstall froze. Forced a reboot, uninstalled the HD Driver(Pro Tools was not available for uninstall) and started over with a fresh install of 12.7.1. We'll see what happens next after the reboot....
Old 03-21-2017, 12:23 PM
jeam25's Avatar
Oh wao...well ! :-/ !
Protools Ultimate
Old 03-21-2017, 12:45 PM
Sadly, things are not looking good here. Another flash of BSOD and a reboot in the middle of a mix...........................................
Old 03-21-2017, 12:50 PM
jeam25's Avatar
Ok thats bad albee ! :-/ ! In my case the times i saw BSOD are firewire related . Maybe trying installing you interface again ?
For the -20007 i found this and it says is related to the IO settings .
Maybe this gives you a hint or maybe not :-/ !
http://avid.force.com/pkb/articles/e...ening-sessions
Protools Ultimate
Old 03-21-2017, 04:01 PM
Thanks for that(no idea why my search didn't turn up this page)
Very interesting as some of my inputs seem to be inactive for no reason I can figure. I can re-select and they work.
Old 03-21-2017, 05:08 PM
jeam25's Avatar
Well thats good ! You're welcome my friend !
Protools Ultimate
Old 09-30-2017, 04:16 AM
mandal mandal is offline
After a big win 10 update...
Yes, seems to be an "I/O setup problem" in Pro Tools
Microsoft Windows 11 Home 64-bit OEM DVD
Avid OMNI PCIe
Pro Tools Ultimate 2023.12
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
get an AAE error -20007 Oli P Pro Tools 11 4 07-30-2015 06:43 PM
bx_rockrack AAE error 20007 gtrm8kr AAX Plug-ins 1 08-02-2013 07:57 AM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
