#81
Re: Eleven Rack Compatibility with MacOS Catalina
Awesome! But now I'm on an M1 Mac - will it work? We'll see!
Update: Doesn't look like it. "System Extension Blocked" - says the developer needs to update the driver.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD. 2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD. PT 2024.3 Native Life is like an Analogy. |
#82
I just installed the driver on my MBA M1. I didn't get the error message, but the interface wouldn't show up either in my audio preferences, although it does show up in the system information under USB. Where does the error message show up that you had?
#83
I don't have an M1 to check, but initial install on my 2019 iMac resulted in similar behavior. I then downloaded/ran the uninstaller from the previous version and ran the new installer again and it worked correctly. I have since been unable to repro the failure with different combos of driver versions so it seemed to be unique to my system (which sees a lot of installs/uninstalls as I'm testing and troubleshooting). Have you tried either running the new installer again, or running the previous uninstaller first?
• linkedin •
#84
I have tried all the recommended fixes on the earlier thread dedicated to resolving the “Error Initializing Eleven Rack MIDI Engine” error when trying to get Eleven Rack Editor to work.
Is anyone able to utilize the Eleven Rack Editor with the new drivers successfully? If so, any thoughts on how to resolve the error I am seeing? Thanks!
Luna 1.5.5, Logic Pro 10.8.1/Logic Pro 10.7.9, Cubase Pro 13.0.30, Studio One Pro 6.6, Pro Tools Studio 2024.3.1, PreSonus Quantum 2, UA-2 Software 11.2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 25, USB FW 1.15 and Axe-Edit III 1.13.19, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Ventura 13.6.6. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.7.1. |
#85
I deleted Editor app. I then re-downloaded the installer for the version I was on, so that I could deploy the uninstaller provided with that version. Uninstalled. Downloaded app again from AVID. Downloaded most recent installer. Uninstalled again for good measure. Installed latest editor app & verified latest firmware. My 11R was not turned on during any of this. Now I’m golden. Good luck Sent from my iPad using Tapatalk
2019 iMac 27" 5k Retina 3.6 Ghz 8-Core Intel Core i9 Mac OS 10.15.7 / 60GB RAM UAD FW Apollo Duo (Thunderbolt Card) PT 2021.3 Eleven Rack FW v2.00.1 / Software 1.2.14 |
#86
Thanks!
Luna 1.5.5, Logic Pro 10.8.1/Logic Pro 10.7.9, Cubase Pro 13.0.30, Studio One Pro 6.6, Pro Tools Studio 2024.3.1, PreSonus Quantum 2, UA-2 Software 11.2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 25, USB FW 1.15 and Axe-Edit III 1.13.19, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Ventura 13.6.6. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.7.1. Last edited by Daveporter33765; 06-18-2021 at 01:04 PM. |
#87
Can anyone confirm full functionality on macOS Big Sur (Intel)?
Thanks!
#88
macOS 10.15 (Catalina) and Avid Products | Avid | Technical Alerts | 0 | 10-07-2019 11:11 AM |
Eleven Rack compatibility options? | needled39 | Eleven Rack | 3 | 10-02-2017 11:48 PM |
Eleven Rack and Ubuntu with Ardour compatibility | CeeJayTheFirst | Eleven Rack | 1 | 06-15-2015 01:33 PM |
Eleven Rack compatibility problems? | fastnboulbous | Eleven Rack | 0 | 03-24-2011 07:08 AM |
Eleven Rack in system settings of MacOS | clausiii | Pro Tools M-Powered (Mac) | 1 | 12-20-2009 07:15 AM |
