  #21
Old 06-24-2013, 08:17 AM
Default Re: Why Did You Go For 11 Now?
I spent that last month suggesting that people NOT jump on the band wagon the instant 11 was released, and, for the last eon, I have been touting drive imaging and cloning as a backup plan that EVERYONE should have in place. I NEVER install any update or software(and I mean ANY) without saving a drive image first. I also keep a cloned drive with the last working version(10.3 since I have moved to 10.3.5). I have installed 10.3.6 and 11 on a separate system drive for experimenting, but all my day to day work is done on the 10.3.5 drive(swapping hard drives is not hard, especially if you run a PC and use a trayless SATA drive cage). Certainly, running partitions is another option that works. Having backup images and/or drives can save you from, not only a sour update, but it can save you from a complete drive crash too
I keep a pair of 2TB USB drives that hold nothing but drive images. I can roll back to PT9, LE8, XP with LE8..........i may never do that, but I CAN.....
  #22
Old 06-24-2013, 09:14 AM
jryser's Avatar
jryser jryser is offline
Albee I for one have ascribed to your suggestion like glue, and it saved my bacon more than once!
I like tinkering in PT11 now so I can get handy within it and get to know it - went from old school analog over the past 36 years to PT two years ago. Fear was replaced with humility and I won't look back! Your "harping" works! Thanks for all you do.
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
  #23
Old 06-24-2013, 09:17 AM
derFunkenstein derFunkenstein is offline
Originally Posted by WernerF View Post
I track with plugins, as I mix as I go, and I mix with plugins. That pretty much relagates P Tools 11 to play around with until ready for primetime. How is this any different in the entirety of the Pro market? I can't get much work done without enough plugins, can you?
I can get an awful lot done with stock plugins. I'll ReWire with Reaper to get VIs for now, and one day I'll come back to a couple of these projects and wonder "Why did I do it THAT way?"
Originally Posted by YYR123 View Post
Nice
I'm just in it for the laughs.
  #24
Old 06-24-2013, 09:33 AM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Originally Posted by Chief Technician View Post
I'm shocked that they continue to provide security updates for Snow Leopard.
I believe they have to in order to keep the hackers out of your OS... a few of the last releases/updates were security updates to prevent hacking, etc... maybe small bugs, but basically just glad they are still ON IT.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
  #25
Old 06-24-2013, 11:01 AM
NuBus NuBus is offline
Well as it Stands 11 seems to be the most stable version I've used Two thumbs up to AVID
  #26
Old 06-24-2013, 12:09 PM
YYR123's Avatar
YYR123 YYR123 is offline
Needs some more plugs in there to get that trophy - so not just yet
Daniel
  #27
Old 06-24-2013, 12:24 PM
Agreed^^^
  #28
Old 06-24-2013, 12:27 PM
WernerF WernerF is offline
Agreed as well.
  #29
Old 06-25-2013, 01:34 PM
JimmyM's Avatar
JimmyM JimmyM is offline
Same here...
can't use my
NI Komplete
Revibe
Sonnox
Spectrasonics
Jimmy Makhaisingh
Producer Mix/Mastering Engineer
JimJam Studio
iMac (Retina 5K, 27-inch, Late 2015)
PT11HD
HDX /HD i/o
Magma Thunderbolt 2.0 Chasis 3T
Manley Vari-Mu / MPassive Mastering version
Sonnox bundle / McDsp / FabFilter /
  #30
Old 06-25-2013, 03:15 PM
boomsounddesign's Avatar
boomsounddesign boomsounddesign is offline
Originally Posted by Drew Mazurek View Post
Short answer? It's the future. If you're a PT user, you almost HAVE to get on the 11 boat early to work out the bugs and ride the AAX2 wave. In a few months, you'll be ahead of the game and if you're using a separate partition (and you are aren't you!?!?!!?) you'll be none the worse for wear.
The future is bright for PT and that's not something you could say for the last few years.
This explains it all. Not to mention I'm opening up a brand new studio so it would be quite stupid to do that with outdated software.
My Gear
Mac Pro (mid 2011) - 2x 2.8GHz Quad-Core Xeon, 16GB RAM, ProTools HD Native, UAD Quad.
HD IO 16x16 + Lynx Aurora 16
Solid State Logic Matrix
B&W 800 series + Yamaha HSM80s
Mojave Audio, Royer, Neumann, Audix, Yamaha, AKG and Shure mics. Focusrite ISA828, SSL Alpha VHD, UA LA610-mkii, M-Audio OctoPre, Avid Eleven Rack
Canare and Mogami cabling.
http://www.boomsounddesign.com
