Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-13-2019, 07:56 AM
George2000 George2000 is offline
Default VI playback is out of time with playback not on quarters or whole notes
Hi everyone,
I've been having this issue forever and I haven't really found a way to solve it yet.
Hope I can explain clearly:
When using virtual insruments if I don't playback (in Grid mode) from an even part of the bar, the timing of the track is completely off. For example, in bar 1 if I playback from the eighth note (or 16th, etc) between beat 1 and beat 2 (the quarters), the timing will be off. If I start playback from beat 1,2,3, or 4 everything is fine. Is there a way around this?? (other than always playing back from an even quarter or whole).
Thanks!
Old 09-13-2019, 08:52 AM
massivekerry massivekerry is online now
Default Re: VI playback is out of time with playback not on quarters or whole notes
I see this with tempo-synched material (like arpeggiators - and which is totally normal) but not usually with “normal” played notes. However, MIDI since 2018 has been unpredictable regarding what the timing is when I play it in (non-quantized) versus how it records and plays back. Delay Compensation might be a factor, but minimizing that doesn’t seem to consistently help.
Old 09-13-2019, 11:32 AM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
If it was delay compensation the issue would occur regardless of where the track starts from.
Which VI(s) are you using during the current session that's giving you trouble? And are you playing long notes (i.e. for drum loops or arpeggios)?
Old 09-13-2019, 01:15 PM
It seems to happen with just about any VI... but I'm currently using NI Kontakt and Arturia Mini V2.
Hybrid and Xpand 2 holding notes doing playback SLJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-21-2009 08:14 PM
Conflicting Notes During Playback BillDog793 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-04-2006 12:42 PM
midi notes won't playback crushed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-02-2006 07:42 PM
MIDI Playback notes cutting out filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-22-2005 09:06 PM
Black MIDI Notes??and no Playback?? B-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-19-2003 02:06 PM
