Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 01-25-2018, 02:43 PM
Jakeman Jakeman is offline
Default Pro Tools First 2018.1 Missing EQ Graph panel
Not sure what I'm doing wrong but the EQ Graph panel NEW feature doesn't show in the View > Mix Window Views menu. Anyone else with this issue? I'm running it on a 13" MacBook Pro macOS High Sierra, 2.7 GHz Intel Core i7, 8 GB RAM, SSD hard drive.
Old 02-05-2018, 08:38 AM
Default Re: Pro Tools First 2018.1 Missing EQ Graph panel
Has anyone used the EQ Curve View in the Mix Window yet in PT First v2018.1? I've tried re-installing PT First 2018 and still don't have the EQ Curve View in the Mix Window.
Jd
Old 02-05-2018, 08:55 AM
Southsidemusic's Avatar
Is it supposed to be in PT First and if it is, maybe you need to activate it under a dropdown menu in PT.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-05-2018, 10:12 AM
That's the problem, I don't see it in the pull down menu:
As per the "What's New In Pro Tools First 2018 page 19:
To show (or hide) the EQ Curve view in the Mix window, do one of the following:
 Select(or deselect) View > Mix Window > EQ Curve.
 Select(or deselect)EQCurve from the Mix Window View selector.
I don't have this in the pull down.
Jd
Old 02-05-2018, 11:07 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I haven't checked on PT First but on Native you right click on the send or insert labels in the mix window and it brings up a drop down menu to show/hide sends, inserts and the eq graph
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 02-06-2018, 08:00 PM
I've tried that also and it doesn't show in that menu either.
Jd
Welcome to the Pro Tools 2018 forum DigiTechSupt Pro Tools 2018 0 01-25-2018 11:35 AM
Pro Tools v2018.1 Now Available DigiTechSupt Technical Alerts 0 01-25-2018 11:06 AM
Namm 2018 Pro Tools new hardware zavid General Discussion 14 11-17-2017 11:20 AM
Volume Graph convert to Trim Graph geosounds Tips & Tricks 1 02-07-2002 09:59 PM
