Old 01-13-2012, 06:41 PM
kinghand kinghand is offline
Default A little suggestion
Why don't Avid produce a single track control surface? My friends and I, we are both using analog consoles for mixing, but we have to make automations on PT, we don't have too much space to place a control surface on the console or beside it. If we have a single track control surface, it will be much better, I know there are single track control surfaces from other manufactors, such as Presonus, but they are really not good enough. So if Avid could provide a single channel control surface with enough good compatibility, that will be great!
Old 01-13-2012, 09:29 PM
jryser's Avatar
jryser jryser is offline
Default
Presonus makes a wonderful one called Faderport. Check it out!
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 01-14-2012, 11:29 PM
tonepad tonepad is offline
Default Re: A little suggestion
Also consider the Alphatrack, which adds plugin encoder/control to the fader. I have both and I favor the Faderport for the basic controls and for the reason that it has a dedicated button for switching from edit window to mix window, which I do constantly. The Alphatrack can do that switch as well but there's an extra button involved, however I've enjoyed using that piece. You can also add/expand to a dedicated plugin controller with the Novation Nocturn, which is a great set of plugin control knobs, which I've used for years. All of them are now offline since I migrated to an Artist Control...the eucon implementation is light years beyond what the simpler devices can do with the HUI protocol.
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 01-15-2012, 10:00 AM
musicman691 musicman691 is online now
Sadly the Alphatrack (as well as the Tranzport) are no longer available from Frontier Designs. Production stopped some time back and there's none available new on the net.
Jack
QAPLA!
Old 01-15-2012, 10:50 AM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
One fader only is really going for the low-end user. I don't think this would do justice to the Euphonix name, which came out with a neat 4 faders-touchscreen interface.
Old 01-16-2012, 04:59 AM
jorg jorg is offline
The faderport was great in Cubase but not so great in Pro Tools as it was really difficult to locate the paramater you wanted to control.
If there was a faderport that used the eucon protocol then it would be great. I'd for sure buy it as 1 fader is all I need to write my automation.
And I don't understand the assumption why you have to be a "low end" user to want that. It's like saying only poor people drive a golf.
Mac Pro Nehalem 8 core 8 GB Ram
OS: 10.6.8
Pro Tools 10.0.1
RME Multiface II with Focusrite Octopre mkII
Old 01-23-2012, 08:54 PM
I would rather buy a expensive single track Euphonix if there is one. I have tried Alphatrack and Faderport, they are not good for working with PT. I know Euphonix is a good controller, and it's cheap, but I don't have room to place it. It's the biggest reason why I want a single track controller.
Suggestion for new pc chaosdemonz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-19-2012 09:02 AM
A UPS Suggestion Please. philip888 General Discussion 17 06-18-2012 01:24 AM
64 bit Suggestion Box edadema Pro Tools TDM Systems (Mac) 11 11-14-2010 04:53 PM
Can You ? or New Suggestion then. Roulette Records Pro Tools TDM Systems (Mac) 10 03-08-2006 03:25 PM
Suggestion for PT 7.0 ................. or PT6.02 Charles D. Ballard Pro Tools TDM Systems (Mac) 8 05-01-2003 08:37 AM
