Old 08-18-2011, 08:55 AM
jorg jorg is offline
Default PT 9.0.5 on OSX 10.6.8 drag and drop issues
I just updated to PT 9.0.5
I noticed whenever I drag and drop any audio file from anywhere (tried all sorts of different files from various locations) on my mac into PT I get a spinning ball for a long time (over 30 seconds) before the file finally imports into PT. This happens with very short 5s files and also with longer 3min files.
I never had this problem with 9.0.3
When I import the file normally via the import menu it works as quick as usual. Only drag and drop seems to have stopped working right.
I tried it on both a blank new session and on existing older sessions. Same problem.
Anyone with the same issue? Any ideas what it could be?
Thanks
Mac Pro Nehalem 8 core 8 GB Ram
OS: 10.6.8
Pro Tools 10.0.1
RME Multiface II with Focusrite Octopre mkII
Old 08-18-2011, 12:01 PM
SessionKat SessionKat is offline
Default Re: PT 9.0.5 on OSX 10.6.8 drag and drop issues
I just dragged 30 files from Finder into the Edit window. It took 5 seconds.
Fresh install of 9.0.5 over 9.0.3 on 10.6.8.
Is Timemachine running? Maybe some other background task(s) in progress?
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
AIR Transfuser Synch Issues with Drag & Drop Loops into Pro Tools 9 NAJM macOS 6 02-11-2011 04:03 PM
sample rate conversion and drag and drop issues jafbox macOS 6 01-10-2011 08:25 AM
sample rate conversion and drag and drop issues jafbox Pro Tools TDM Systems (Mac) 0 01-07-2011 10:23 AM
Couple issues: 1.Drag & Drop in session not working. - 2. PSP VM won't authorize. DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-17-2010 09:52 PM
Copy and Paste(drag and drop) issues HB1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-14-2009 04:27 PM
