Old 12-10-2010, 11:04 PM
drumster drumster is offline
Default Avid Mbox vs. Apogee Duet - Mini Review
For the past several weeks, I've been testing out both the new Avid Mbox and the Apogee Duet as potential candidates for my portable writing and editing rig. My local dealer was kind enough to allow me to take both units home for testing in order to gain insight into how well each functions within Protools 9. As you can imagine, I was extremely keen to compare the sound quality and functionality of both interfaces, especially since the new MBox has been touted as a Duet competitor.
First of all, I want to say that Avid's done a remarkable job in re-designing the new Mbox. In fact, it's worlds better than the previous generation Mbox 2. So much so that I think they should have considered renaming it entirely. I still own an Mbox 2, so I set it up along side the other two interfaces in order to form a baseline comparison. As expected, I was immediately reminded of it's poor sound quality and sub par stereo imaging. Thankfully for Avid, those days are long behind them along with the Digidesign name, so what's on offer here is quite an improvement.
IMHO, the strong point of the new Mbox is the monitoring stage of it's converters. I found the monitoring stage to be transparent and detailed when listening to the PT9 demo track, "The Legion", as well as some of my own songs and several commercial tracks. The Duet by comparison possessed a more coloured sound akin to subtle tape saturation and sounded more smeared to my ears. I slightly preferred the Mbox to the Duet in this regard, but that's just my personal taste. I felt that what I was hearing through the Mbox was quite accurate.
Both the Duet and Mbox have their own cue mixing software of which I found very easy to use. The included effects on the Mbox aren't unbelievable, but are more than adequate for monitoring purposes. When a colleague of mine asked me today about the sound quality of the built in reverb I compared it to Dverb because it's similar to that. The Apogee Maestro software doesn't include any built in effects, but that wasn't an issue for me as I don't mind tracking vocals without effects for quick demos. For others this might be a consideration, but I was quite happy to record dry. Another thing I found was that it was easier to get a good monitoring balance with Maestro compared to the MBox software. In general, Maestro was seamless and easy to use. Some people have reported problems with it and PT9, but I didn't run into any issues with either my MacBook Pro (Core 2 Duo) or Mac Pro (8 Core).
For the purpose of testing the pre-amps, I recorded vocals through both interfaces using the following microphones: Shure SM57, Shure SM7B, AT 3060 and Josephson C42. This is where the real difference between the two units became apparent. When recording through the Mbox, I really had to crank the gain up to get a decent signal going in (at least 85%). I also didn't find it very elegant or responsive to small increments in gain adjustments. Perhaps it was just my unit, but the gain knob sounded quite noisy. With the Duet, this was not the case at all. I was able to turn the gain up to halfway and get a nice, clean signal. It was sensitive to gain adjustments and seemed to handle every task with ease. The resulting output from the Duet was detailed and crisp and had a smooth definition. The Mbox sounded darker, less detailed and 2D in comparison, making the Duet the clear winner in this category.
Unfortunately, today was the last day of my loan period for both units, so I had to return them back to the store. I was actually a little sad to part with the Duet because I was enjoying using it so much. The good news is that I have an RME Babyface on order, and that should arrive any day now. I have no idea how it will stack up against the Mbox or the Duet, so I'm waiting until after it arrives and I get a chance to try it out before making my final decision. My dealer has generously offered to allow me to take the Duet out again when the Babyface arrives, so I can compare both units. Needless to say, I am really looking forward to that!
In conclusion, although the new Mbox is a substantial leap forward for Avid, I would still choose the Apogee Duet. YMMV, but for it's excellent price point, small footprint and quality sound within this range, the Duet is a classy little box. Don't get me wrong, it's not up to the level of a Lynx Aurora but still very impressive for a $500 interface. I could actually see myself recording some keeper tracks through the Duet without the need to re-record them through a more expensive signal chain, and that to me is a real advantage.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
Old 12-11-2010, 07:24 AM
Onager1286 Onager1286 is offline
Default Re: Avid Mbox vs. Apogee Duet - Mini Review
Thanks for the interesting read. I have an MBox 2 Pro and I've always wanted to compare some other gear to it since I always hear its sound quality is supposedly terrible.
Unfortunately the thing that holds me back from getting a Duet is that it won't work with Windows. I need my gear to be platform agnostic.
Old 12-11-2010, 01:41 PM
gracejames gracejames is offline
Thanks for the review. Enlightening. Have you had any stability issues with Duet Drumster? Anyone?
Old 12-11-2010, 07:11 PM
The only stability issue I had with the Duet was the presence of hardware buffer errors when I switched back and forth from the HD TDM engine in my main studio (Mac Pro). I wanted to compare the differences between the TDM engine and the native engine within PT9 and used the Duet as my native interface. The strange thing about these errors was that they occurred without any plugins on the track. This didn't happen with the Mbox, so I'm wondering if it had something to do with Core Audio getting screwed up after PT9 had recently been used with the TDM engine. This is really a guess though and probably wouldn't affect most users. The good news is that when exclusively working in Native, switching between the Mbox and Duet was seamless and without any hiccups. There were absolutely no buffer errors to speak of at all. To answer your original question, I would rate Duet as a very stable, third party interface within Protools 9.
Old 12-12-2010, 03:01 PM
Appreciate that drumster. I am using native.
Old 12-19-2010, 12:01 AM
Drumster, just wondered when you tested the Duet, since that is firewire, did you use your internal drive to record the audio on your MBP or a USB ext drive? Isn't that an issue since Duet is using the FW port or did you daisy chain an ext fw drive to Duet? Did you get your RME babyface yet?
Old 12-19-2010, 05:56 AM
As per the approved protocol with Protools, I recorded my audio to an external, G-Tech Firewire 800 drive. Since this was an older drive, it actually had a FW 400 port on it, so I simply hung the Duet off of that. That being said, you could easily do the same thing if your external drive only had a FW 800 port. You would just need to use the 400-800 Adaptor cable which comes in the box with the Duet. There were absolutely no issues with this daisy chain configuration i.e. no audio dropouts, weird crashes ect. One thing I didn't try, however, was daisy chaining the Duet in a configuration involving 2 external drives (one for audio and the second for sound libraries).
I still don't have the Babyface yet, but my dealer told me that it may arrive by late next week. I can see it working well with two external drives because it'll be running on it's own off the USB port.
Old 12-20-2010, 10:25 AM
Escape Escape is offline
Thank you very much for this review.I hope when you get the babyface you will post back with some results.I'm very interested for the preamps of babyface since it offers a 60db of gain compare to duet 75db i think.Please test the preamps with the same shure mics if you can.Keep up posted.Thanks again
Old 12-20-2010, 01:32 PM
getz76 getz76 is offline
It should be interesting. I believe the RME Fireface 400 and the Duet use the same TI chip for A/D and the preamps. I bet the BabyFace uses the same, too.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 12-20-2010, 02:14 PM
Appreciate the feedback. So, daisy-chaining a firewire interface to the firewire drive is approved by Digi then? I've been out of the loops with audio for a while. Just want to make sure i set up my MBP properly. I'm planning on getting a digi approved drive. PT9 opens up new possibilities with these different FW interfaces. From your review, the issue isn't the converters but more the built-in micpres. I may still go with an mbox3 and couple it with a high-end BA or UA mic-pre.
Apogee Rosetta 200 (MINT), Lynx AES16e-SRC, Apogee Duet, BBE 882i, OFFERS ENTERTAINED jrhager84 Buy & Sell 5 03-11-2013 01:25 AM
Pt 9 and apogee duet 1 sidneyjohn Pro Tools 9 1 02-21-2013 09:07 AM
WTB:WTB: Apogee Duet 2 postman56 Buy & Sell 2 09-21-2012 05:37 AM
Apogee Duet 2 is out! nst7 Pro Tools 9 2 03-31-2011 12:23 AM
If your using PT9 with the Apogee Duet..... Amin7b5 Pro Tools 9 12 12-07-2010 10:05 AM
