5.1 mix printing question
I am mixing a TV show in 5.1 surround (PT9) and have a problem printing. I have set up a 5.1 monitor and print bus that allow me to hear and see the resultant tracks on a record channel. All tracks show up when printing EXCEPT the LFE track. It makes no sense because if the other tracks are routed correctly and record, why should the LFE track not record as well?
The session is big enough to push the limits of the TDM/RTAS resources I have on board, but to me that doesn't explain why one of 6 tracks won't print. The LFE shows up on the 5.1 monitor track and the 192 interface, but doesn't on the 5.1 print track. Has anyone encountered this or have a clue why this is happening? Thanks! |
Re: 5.1 mix printing question
So you are saying that the meter on your LFE re-record track shows a signal but there is no waveform? Or is there just a LFE signal present on your monitor bus?
Check that your bus is routing the signal correctly?
printing a score | rbsalyer | Pro Tools 9 | 1 | 07-21-2013 12:45 PM |
Printing Mixes : Level: another stupid question (obviously) | midnightrambler | Pro Tools TDM Systems (Mac) | 30 | 09-11-2009 10:04 PM |
printing mix on 5.1 | simplemix | Pro Tools TDM Systems (Mac) | 3 | 10-04-2007 09:25 PM |
Printing fx | Pietari Koskinen | Pro Tools TDM Systems (Mac) | 1 | 09-15-2002 04:01 AM |
Question about printing just effects to a track | DLW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-14-2002 03:23 AM |
