Eleven Rack and Ground Control Sync
So I have never been able to figure this out. When I configure a tone in the Eleven rack and plug in the Ground control to use it, the Lights that coinside with each effect do not synch up with the ground control.
This is frustratung when using live- I'd like to be able to scroll through settings and have the corresponding lights on the GC tell me which effects/ compressors/etc are on without having to look at the Eleven rack each time. Can someone please provide some advise on how to make this happen? |
Re: Eleven Rack and Ground Control Sync
Never Mind- Got it...
So, what did you do to get it to sync up? I am new to the 11R too. I have the Sweetwater bundle with the 11R and the Ground Control Pro. They come with artist presets.
You have to save the GC patch with the lights in the initial state the 11R patch are at. Once it's been 'manually sync'ed' (for lack of a better term) then the GC will show the appropriate On / Off state. It doesn't actually get the indication from the 11R.
Sorry if Im not describing it clearly. |
Eleven Rack and Ground Control Pro | prodigy_ed | Eleven Rack | 4 | 04-07-2018 08:34 AM |
Eleven Rack & Updating Ground Control Pro to presets | TheGuitarGrandpa | Eleven Rack | 0 | 11-30-2017 08:53 AM |
Eleven Rack and Ground Control Pro Problem(s) | wpawley | Eleven Rack | 3 | 07-03-2016 01:51 PM |
Eleven Rack & Ground Control Pro Template | guitarorth | Eleven Rack | 2 | 03-10-2012 01:33 PM |
Eleven Rack Ground Control Pro Axiom 25 | Scott Paige | Eleven Rack | 1 | 10-19-2010 02:15 AM |
