Sept 2015 -- which version of EuCon is most stable?
The updates aren't making EuCon any more stable for my companies configurations which use EuCon, in fact they seem even more buggy over time.
I think we may need to downgrade to an older version. In your experience, which has been the most stable? FWIW we're using PT 10.3.10 with OS 10.9.5 |
Re: Sept 2015 -- which version of EuCon is most stable?
Haha! ...so, none of them then? I should have expected this.
Well the last version I seen others say was the best and most bug free was 2.7.1 so check that version out and see what your experience is, we have used 2.7.1 - 3.3.1 and haven't yet had any issues we could find.
What problems are you having?
For McMix I'd Use the 3.0.1 version. All versions after that suffer from malfunctioning "Shift+Fader sets level to 0db" -feature.
Our controllers drop off the planet at least once per session. We have to re-add the controllers to the session manually, or restart all EuCon apps, or power cycle the controllers, or restart the computer, or some combination of the above. Avid has stopped responding to my tech support emails. EuCon is rising to the top of my Worst Applications I've Ever Used list. The Avid guys looking at the issue are good dudes, unquestionably, but something is awry, probably at a higher level, because this issue keeps falling by the wayside. Meanwhile, our controllers are a nightmare.
What controllers ? Artist's series? Or S3?
For my set-up, the EuControl v 2.7.1 was the most stable version by far. At the present version 3.3.1, I notice the same issue as described above. I think, if I extensive change pages on the AVID Artist screen, for some reason, the connection get lost and must be re-setted within the Cubase application. This is not really a new behaviour, but is more often than before. Cheers
**************************************** ALSTUDIOS REGENSDORF SWITZERLAND [email protected] https://sites.google.com/site/alrecordingstudio/ 1pc AVID Artist Control and 1pc Euphonix MC Mix Win11 64Bit, Cubase Pro 12.0.52 **************************************** |
3 Artist Mix and 1 Control
eLicenser Control (eLC) updated to Version 6.8.5.1165 released April 7th, 2015 | unkJE | Virtual Instruments | 4 | 04-25-2015 10:12 AM |
eLicenser Control (eLC) updated to Version 6.8.5.1163 released March 9th, 2015 | unkJE | Virtual Instruments | 1 | 03-13-2015 03:40 AM |
eLicenser Control (eLC) updated to Version 6.8.5.1162 released February 23, 2015 | unkJE | Virtual Instruments | 1 | 02-25-2015 11:33 AM |
eLicenser Control (eLC) updated to Version 6.8.5.1161 released February 10th, 2015 | unkJE | Virtual Instruments | 2 | 02-11-2015 01:52 PM |
Eucon 2.7 stable again, thank you. | Audioartist | Artist Series | 4 | 03-24-2013 07:42 PM |
