AUDIO WON\'T LOAD from Firewire Drives
I have a serious problem here that i've been experiencing for over a year now,I have 3 firewire drives and i usualy work between OSX with M Box, HD and TDM & 9.2 TDM systems.Going Back & forth between all formats with no issues until July last year one day.I started getting and error message saying " This Is not an Audio Playback Volume,and asked me whether it should copy all audio files to a suitable Playback Volume" it does'nt load any of the file sin My session,but then when i go to a TDM System or HD it loads and plays perfectly well, this error message only happens when i try to load up a session on my M Box system .If anybody caN ASSIST ME WITHT HIS I'D BE VERY VERY GRATEFULL TAHANK YOU.
NativeXamaycan "Out of Many,One Groove... |
Re: AUDIO WON\'T LOAD from Firewire Drives
You need to make sure that your Firewire drive is set as a Record volume in the workspace window. Under the Window menu, go to workspace, make sure there is an "R" under the "A" column. Right now there is likely a T or a P (Transfer and Playback)
This preference seems to get changed sometimes if you open Pro Tools without the drive mounted or if you use the drive on another machine, etc. |
firewire drives no longer valid audio drives | chuckbody1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-22-2006 11:04 PM |
Firewire Drives vs. ATA drives for Audio Playback and Recording | Chence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-26-2003 12:59 AM |
Firewire Drives: "selective" invalid audio drives?... | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 02-26-2003 07:17 AM |
Firewire Audio Hard Drives | MacPhearson | General Discussion | 1 | 05-29-2001 03:34 PM |
FIREWIRE AUDIO DRIVES?? | JonInside | Pro Tools TDM Systems (Mac) | 14 | 11-19-2000 12:55 AM |
