Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 10-13-2017, 12:00 PM
tuchel tuchel is offline
Default HEAT: is "Buss" a Post send?
Regarding HEAT, If I were to Buss out several tracks together to a new track with HEAT in the "Post" mode...is the "effect" recorded?
Thanks;
tuchel
Old 10-13-2017, 02:04 PM
Dan IceWood Dan IceWood is offline
Default Re: HEAT: is "Buss" a Post send?
Pre and post in regard to HEAT, references HEAT processing pre or post the 10 insert slots. Any channel with HEAT engaged that is then bussed to an audio track to bounce down to will record the heat processing.
controlling "HEAT "plugin with Dcommand ? francois ICON & C|24 3 08-17-2015 01:48 PM
No effect with HEAT's "Drive" knob in the first position to the right midnightrambler Pro Tools 12 3 07-08-2015 02:15 PM
New Mixing Product for PT HD called "HEAT" Tom Graham General Discussion 27 09-17-2010 12:47 AM
MIDI "program change" send=buffer overflow on target triplex Pro Tools TDM Systems (Mac) 5 09-01-2010 03:14 AM
"Buss" and "Plug in" words grayed out... amba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-10-2008 04:23 PM
