Plugins to Audio file
Hello,
I'm sending my Pro Tools project someone else, but he doesn't have all the plugins I'm using. At the moment I'm recreating the plugins with the AudioSuite so they effect my audio file and the other person doesn't have any problems with opening my project. My question: is there a simpler way to do this? Is there a quicker way to merge your plugins with the audio file? RTD |
Re: Plugins to Audio file
Thats the quickest way, the alternative is to print which is then real time.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Maybe a simpler way:
1. Create 1 new audio track for each track currently in the session. 2. Cascade the input busses on the new audio tracks (start with the first open bus and it will cascade inputs on the tracks upward from there). 3. Cascade the outputs of each of your audio tracks to the newly assigned input busses on the audio tracks you just created. 4. Record enable all the new audio tracks and engage transport record. This will 'bus record' each of your audio tracks to a new track, which you can then select and export as audio files. I advise saving your session before doing this in case you make a mistake in assigning outputs and need to revert back to the original state. |
That doesn't appear to be easier
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB |
Question: Converting an audio drum file to a MIDI file? | ctyelvis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-18-2010 06:56 AM |
My Audiosuite plugins won't write to the audio file | trizzent | Pro Tools M-Powered (Mac) | 2 | 09-01-2007 04:56 PM |
bad file: can't read or copy audio file | minister | Pro Tools TDM Systems (Mac) | 10 | 11-20-2005 04:59 PM |
applying pitch to an audio file from a midi file? | catjamz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-04-2004 08:40 PM |
Compressing a Pro Tools file to a Audio file (Mp3) | Funkmaster69 | Tips & Tricks | 7 | 02-26-2004 11:08 AM |
