iLok Driver Installer wont install
Just got windows 8 Pro and everything is going fine till I try to install iLok Driver Installer (DriverSetup.exe)
The file opens then just sits there with the bar filling up over and over again. it's installing required Microsoft dlls and never finishes. On the Ilok site windows 8 is supported. What can I do? Thanks in advance.
Ibanez RG7 Marshall Valvestate VS30R Pro Tools 11 Boss GT-100 Intel Core i7 2600K @ 3400MHz Asus P8Z68-V PRO GEN3 16384 MB Ram GeForce GTX 660 Ti Win 8.1 Pro 64X Thing of it is see, Ya know what I'm saying? |
Re: iLok Driver Installer wont install
Ok uninstalled everything that has to do with pro tools reinstalled only pro tools and now getting "Could not allocate memory for the disk cache. Tyr lowering your disk buffer (DAE Buffer) disk cache size or engine voice count. If you got this error on launch, delete your prefs and try again. (-9514)"
Did that now I get "DAE Error -13001 was encountered" Crazy!!!!!! Found the fix is to run pro tools as admin that gives me the delete your prefs error or the -13001. Ahhhhhhhhhhhhhhh this sucks.
for transmitting your string to your iLok you´ll need always an old system ... I made this experience two weeks ago. Pace iLok is just running for installing strings on 32-bit systems. When your string is at your iLok you can use other OS´s |
Avid has not qualified and, at the moment, does not support Windows 8 as an OS for Pro Tools.
Cheers,
If that's the case you think installing a Virtual Machine(VMware I believe) program and run say win xp in it then get PT 10 up and running exit xp vm. Reboot win 8 and maybe just maybe PT will work in win 8? Ooooo I'm exited :)
VM is slow.
If this wont work ill have to install win 7 on diff drive and use it for PT only till win 8 update happens. what a shame. Thanks for the help and if anyone has another suggestion please post it ill give it a try
Pro Tools runs best without other apps installed on the same OS anyway. So this is probably a good idea.
ILok driver won't install | poppy | Windows | 7 | 06-22-2012 10:18 PM |
Machine Control BIG installer bug, wont start | rbhun | Windows | 10 | 02-11-2011 07:26 PM |
6.7 Install Fails On PT Driver Installer | Third Eye Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-01-2006 11:28 PM |
Mbox driver wont install - freezes computer | dharpo32 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-20-2005 09:12 AM |
Trying to upgrade to 6.4 but installer wont work! | yogitengu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-01-2004 02:05 AM |
