Old 01-19-2002, 04:36 PM
Bookerv12 Bookerv12 is offline
Default So let me get this straight...
Hi everybody,
Hopefully the debris has settled a little,,,
So......
If I get a 192 box, I will be able to have 16 ins, plus...I can hook up the ADAT bridge for a total of 16 more?
Is that with the single or expanded PCI card setup?
Thanks,
Booker
bookerv12
Old 01-21-2002, 11:33 AM
Default Re: So let me get this straight...
Anybody?
bookerv12
Old 01-21-2002, 11:44 AM
Kevin Mooney Kevin Mooney is offline
At 48K, Yes.
At 96K the Legacy port is not active.
Old 01-21-2002, 05:34 PM
EthanMorse EthanMorse is offline
No, I believe its for a total of 16ins. If you use the 16ins of the adat bridge then the other inputs cannot be used simultaneously...(I'm pretty sure...but I could be wrong)
Old 01-21-2002, 07:26 PM
Shawn Simpson Shawn Simpson is offline
Yes, you're wrong. Each card can support up to 32 channels of i/o. That means the 192k can have up to 16 channels of onboard i/o to use simultaneously + the legacy port can have another 16. It's true that the legacy port is not active at sample frequencies beyond 48k though. It's gonna take a little while to shake out all of the configurations. Happy samplin'!!
Old 01-21-2002, 07:30 PM
D Clementson D Clementson is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by EthanMorse:
No, I believe its for a total of 16ins. If you use the 16ins of the adat bridge then the other inputs cannot be used simultaneously...(I'm pretty sure...but I could be wrong)<HR></BLOCKQUOTE>
Each HD DSP card can handle 32 simultaneous bidirectional I/O channels via the DigiLink cable. The first I/O box in the daisy-chain (either 192 or 96) splits those 32 into two 16 channel groups: one group is dedicated to the analog and digital conversion within that box, while the second group is either sent to the second box in the daisy-chain (via the Expansion Port), or is sent to the Legacy port. The Legacy port can connect one 16-channel Legacy box (i.e. 1622), or to two 8-channel Legacy boxes (888|24, AD8000, etc.) via a "Y" cable. Of course, the Legacy port only works at 44.1k/48k.
DC
Dave Clementson
Digidesign Engineering
Old 01-22-2002, 12:22 AM
zaraz zaraz is offline
Can you run more than 16 I/O from a single interface? for example, if I had the extra A/D card in the 192 I/O could I also use the digital I/O for 24 inputs on one interface, or would I need a second unit for that?
Old 01-22-2002, 11:01 AM
DigiTechSupt's Avatar
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by zaraz:
if I had the extra A/D card in the 192 I/O could I also use the digital I/O for 24 inputs on one interface, or would I need a second unit for that?<HR></BLOCKQUOTE>
16 is the maximum number of simultaneous I/O an interface can handle. In order to increase that number, a second interface is required.
Brent
Avid Audio Tech Support
Support FAQ
Old 01-22-2002, 11:43 AM
Krusty Krusty is offline
16 i/o at once / per interface
32 i/o per CARD
take your pick of analog/digital/optical
you can then daisy chain a 96 i/o or Adat bridge, etc. to it.
Old 01-22-2002, 11:55 AM
lionel payet lionel payet is offline
Well, I'm lost. I want to input simultaneously 32 adat from gigasampler (in 44,1), do I need 192 I/0 ( 2 adat 8)+ adat bridge (2 adat8), or do I need 192+96+adat bridge ?
Thanks
http://www.l2pmusic.com
Can someone set me straight on AAX? gtomassetti macOS 5 10-24-2011 09:50 AM
Let me get this straight reflexson Pro Tools 10 3 10-20-2011 11:37 PM
Let's get this straight.... YoRugMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-15-2010 11:37 AM
Let me get this straight.. voce Pro Tools TDM Systems (Mac) 51 07-29-2005 11:03 AM
So let me get this straight!! irwinmfletcher Post - Surround - Video 12 02-16-2005 04:22 AM
