Old 11-23-2017, 09:44 AM
jeffpardo jeffpardo is offline
Default PT sessions on internal SSD
Question for smarter people than me. :)
Let's say I buy either an new iMac Pro next month or a refurb 2013 Mac Pro with a blazing fast 1 TB internal SSD - does it matter anymore if I run PT sessions on that internal drive? Does it still hurt performance and stability like it did back in the day of slower, 7200RPM drives?
Thanks!
Old 11-23-2017, 09:49 AM
Default Re: PT sessions on internal SSD
Nope. It will work much better than most external drives most folks have.
Old 12-10-2017, 03:00 PM
Following up on this....one further question.....let's say I get a 4 TB internal drive, with 2.5 tB dedicated for samples, 1TB for sessions......is it insane to run all this on the same drive? Let's say it's an iMac Pro. :)
Old 12-10-2017, 04:40 PM
"dedicated"? You mean partitioned?
You don't partition for performance, that slows down an HDD and does not help an SSD. You partition to support multiple boot images, multiple different filesystems if required for some reason, or maybe for backup/recovery reasons. In fact if you have to ask... definitely use one large partition.
The "is it insane to run all this on the same drive?" question has been answered in DUC oh hundreds of times at least, by me alone.
Old 12-12-2017, 07:36 PM
Sorry man, I can't find your answers to this question....apologize if it's been asked before.
I don't mean partitioned.
What do you think? Don't do it?
Old 12-12-2017, 07:49 PM
Southsidemusic's Avatar
If you meant that you wanna use 2.5 TB for one thing and 1 TB for some other files then no problem as long as you leave the drive as it came i.e. no partitioning.
A fast SSD will be able to run a LOT of data back and forth.
We have maybe 25 SSD's here, all Samsung and we have some for both sample libraries and sessions when we are on the move and Not at the studio in Thunderbolt cases but in the studios we have dedicated SSD drives for sessions and libraries.
So the answer is maybe get two 2TB SSD's if you wanna be sure not to over provision the one 4Tb drive. I would get two instead so you can have more control over that as you might not have many SSD drives.
All IMHO of course.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-13-2017, 04:26 AM
Do NOT partition. Partitioning was necessary when there was a limitation on the size of drives Windoze supported IIRC but nowadays not needed at all (unless as was written you want to have different boot partitions).
Old 12-14-2017, 07:04 AM
Which Samsung SSDs are you using, Southside Music?
Old 12-14-2017, 08:07 AM
noah330 noah330 is offline
I would go with whatever Darryl says. His advice is always spot on for this stuff.
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 12-14-2017, 08:56 AM
I'm not SSM but I'm using Samsung 850 EVO's here. Decent price and who needs the extended warranty of the Pro versions? If you want good prices on Samsung ssd's check out B&H online - that's where I get mine.
Error 9073; Can I import old sessions off an internal disk? chazmuz macOS 2 02-03-2016 03:59 AM
copying PT sessions from PC internal to Mac external SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-10-2010 07:35 AM
~~~ Running sessions on internal drive on Powerbook G4 ? ~~~ waterbedman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-12-2007 11:51 AM
Switching an internal HD(with sessions on it) from one pc to another.... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 01-04-2003 03:37 PM
Do 16 bit sessions alter HD's internal Headroom? schmeete Pro Tools TDM Systems (Mac) 3 09-27-2002 10:26 PM
