Is it possible to rescan plugins?
After this Post,
Im with a Pro tools 9 without my Instruments and Plugs. This is really bad, Is there any way I can rescan my system as in (the reliable) Nuendo and get my Plugins back or I need to reinstall all my tools? This process is VERY time consuming. Thank you |
Re: Is it possible to rescan plugins?
Delete your Prefs. This will cause the plugs to rescan
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I did that.
Only the Pro tools plugs are back - nothing of the komplete 7 or any other 3rd party plugin is recognize by the pro tools. why is that? |
You may have deleted the entire DAE folder or the Plug-in folder within the DAE folder. When you reinstalled the update it only added PT stock plugins. Check the Plug-ins folder in the DAE folder. If no 3rd party plugs are there then that's most likely what happened. BTW, if you want true "system restore" get Acronis True Image 2011 and keep a clone and/or backups of your drive. |
Yes,
The DAE is empty. Do I need to reinstall everything? |
I'd uninstall PT then do a clean install. For your 3rd party plugins you should only need to reinstall the RTAS plugins for them, not the libraries. Next time just delete the DAE Preference folder within the DAE folder.
Basically, yes. You have to run all your 3rd party plug-in/VI installers to get necessary .dpm files into the DAE Plug-ins folder.
BcA. Tomas Vitha Sound Designer and Mixer 2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24 |
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library | Roll | Buy & Sell | 5 | 03-11-2013 06:20 AM |
AMS Rescan and Patch Name Problems | artk2002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-07-2012 07:29 PM |
Lateny Issue with PT8, 2009 mac Pro (OSX) and NI Plugins/Spectrasonic Plugins | djtorch | Pro Tools M-Powered (Mac) | 1 | 01-14-2010 12:11 PM |
Plugins missing in drop down list, but in plugins folder ?? | mixingmadness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2007 10:27 AM |
PLUGINS problem - paid for factory plugins, DON"T WORK!! | rhinostylee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-28-2007 10:59 AM |
