Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-27-2010, 10:52 AM
djraz69 djraz69 is offline
Default Help. Rec Issue with PT 8.1
When a hit record there is a 6 to 10 sec lang before recording starts. i've tried everything i can think of. Any suggestions out there? i even tried the ProTools_Prefs_&_Database_Helper but either i did not use it right or it did not help with the issue.
thanks robbie
Old 01-27-2010, 11:45 AM
DigiTechSupt's Avatar
Default Re: Help. Rec Issue with PT 8.1
Do you have 2 Bars enabled in the transport? Another suggestion - try setting your Open Ended Record Allocation to something like 10 minutes.
Avid Audio Tech Support
Support FAQ
Old 01-27-2010, 11:57 AM
Default 2 bars
I think it is on however how do i turn it off?
i'm going to be embarrassed if it's that easy. however i was always suspicious of the 2 bar thing but could never figure out how to disable it.
thanks
robbie
Old 01-29-2010, 11:17 PM
necjamc necjamc is offline
if you go to the window menu and open the larger transport, you just deselect the count in button. If you don't see it, click the arrow on the right of the transport window and select midi controls. If the count off button is lit, click it to turn it off. Also are you using a separate HDD for audio? Using only the OS drive can cause PT to start slow and work sluggish and unpredictable.
Old 01-29-2010, 11:19 PM
Sorry its also available from the edit window transport at the top of the window. Same thing aplies if you don't see count off the click the arrow in the upper right of the transport box and select midi controls from the drop down menu.
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue ZDF macOS 0 01-14-2013 02:47 PM
weird crash issue PTx and possible procontrol issue, need help Cryos Pro Tools 10 5 12-08-2011 05:17 PM
Some regions had invalid bounds... non-issue becoming a crash issue!!! krichu Pro Tools 9 3 12-11-2010 04:49 AM
Digi 002 Power Harness Issue or Firewire Chip Issue? Nish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 35 05-07-2010 01:25 PM
002 Console Issue, Faders Wont Move (grounding issue?) guitar486 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-01-2010 03:58 PM
