Commit doesn't work with Midi clip and VE Pro
I tried using commit for the first time on a midi clip and it didn't work.
The midi clip is accessing samples from a slave computer that is hosting VE Pro. When I play back the midi clip before I Commit it sounds fine. So then I did the commit function and Pro Tools does the offline bounce but comes back with a audio file that has no audio. What am I missing?
- Steve 2013 iMac Late model i7 3.5 Ghz quad-core, 24 gigs ram, OSX 10.12.3 PC slave, i7 6700 4.0 Ghz quad-core, 64 gigs ram, SSD drives running VE Pro 7 Multiple external thunderbolt SSD hard drives UAD Apollo X8, Twin Duo & Quad Satellite Thunderbolt Townsend Sphere L22 w/ Putnam Mic Collection LUNA (I have Pro Tools 2020 as well) |
Re: Commit doesn't work with Midi clip and VE Pro
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
I could try committing from one of the aux outputs but I was trying to see if the midi commit would work for a specific midi track from a multi timbral set up. So my next question is, does midi commit work allow you to isolate one midi track from a multi timbral set up or does it just work with the instrument track only?
If you have vepro instruments routed to different auxiliary inputs on protools you can commit the auxiliary inputs or the whole veppro instance. If you do the auxiliary just the one you commit will render but if you do the veppro instance all the auxiliary inputs will render. This is how I usually work. I never tried to commit the Midi track itself.
Sent from my SM-G935V using Tapatalk |
Quantize to Grid doesn't work when set to Clip/Markers | myca | macOS | 16 | 12-28-2014 04:03 PM |
Clip editing from the surface doesn't work | tamasdragon | Avid S4/S6 | 13 | 12-24-2014 07:54 AM |
10.3.8-When vertically dragging a clip that shares a crossfade... STILL DOESN'T WORK | simonchase | Pro Tools 10 | 0 | 01-01-2014 02:14 PM |
BUG (?): Match clip doesn´t work on split mono | Frank Kruse | Post - Surround - Video | 5 | 12-17-2008 06:34 AM |
Clip Light Doesn't Work In Playback | brianpatrick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-07-2003 09:06 AM |
