How do I go about getting the \"screw voice\"
I say screw voice for lack of a better term, does it have something to do with the audiosuite, if so I do know anything about it, any help would be greatly appreciated.
And before someone says "use search"............................I have
http://www.soundclick.com/soufcentrol<~~~Check out some of my music |
Re: How do I go about getting the \"screw voice\"
Can I get a lil help, does anyone even know what I'm talking about
You're talking about the technique popularized by DJ Screw called "screwing" tracks, which originally was just slowing down the tracks, but copying the technique has led some to just pitch shift the tracks down.
You can use the DigiRack pitch shift to do both.
OK thanks for the info, but can you go into detail a lil bit, I guess some helpful techniques
So you don't understand "Pitch Shift"?
Select the region you want to "screw" Select the Pitch Shift plugin from the Audiosuite menu Adjust the coarse setting to a negative semitone (how much or how little is your personal preference) click preview to check the settings click process to process the region. That's pretty much it. Getting it to sound exactly like you want it to is up to you. I would actually recommend using the new Time Shift plugin for this if you have it installed (most people using newer versions of Pro Tools do). Keep in mind that you are actually changing the tuning when doing this, so if you are doing it on tracks that actually have a melody, and not just spoken or rapped, it will change the pitch so that it will no longer be in key. If you want to do this without changing the pitch, you will have to use one of the vocal plugins that can change the formant, like Antares Avox or Celemony Melodyne. Using those correctly would require too much instruction for a quick tutorial here, though.
I knew how to do all of that but couldn't get it on the track, but I chilled out grab a brew and took my time and I found out how to get it on there, don't know if it's the right way but it works lol but once again thank you for your help
You can chop and screw in Pro Toolz but that aint how they do it in the studio. PT is a recording platform. To chop and screw you need to sample the audio first and use either a MPC or Reason's NN-19 sampler so you can control the pitch and the ability to control it thru your keyboard for repitition; like the King Kong song..(If ya hear me fo ya see me I got King Kong in da trunk)...if you dont know what I'm talking about then nevermind; some hood rich stuff is just the unwritten ghetto code.lol..hollatchaboy
Re: How do I go about getting the "screw voice"
Or you could do a blend of Melodyne and Pitch Shift, Serato PnT (Pitch n Time), AutoTunes Formant automation tweaking, whatever you think screwed should be for the tracks sound.
The thread is from 7 years ago, hopefully he figured it out by now.
Did I screw up? | steve.h | Pro Tools 9 | 3 | 04-20-2011 12:23 PM |
voice band multitrack instruments and vocals all from voice input for iphone | crizdee | Pro Tools TDM Systems (Mac) | 1 | 01-12-2010 02:56 PM |
Did I screw up? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-29-2006 11:01 AM |
Voice weirdness: tracks play wrong voice - any suggestions? | citysoundman | Pro Tools TDM Systems (Mac) | 17 | 10-03-2002 01:45 PM |
44.1/48K screw up | CFS | Pro Tools TDM Systems (Mac) | 2 | 09-07-2001 07:40 AM |
