Old 11-19-2017, 04:35 PM
someone someone is offline
Default Bit Crush/Project Crash Bug
anyone know of a solution to pro tools' bit crush bug that takes over a project now and then? you know, you're in the middle of working on a project that's starting to get fairly intricate and then the audio drops out and suddenly turns all horrible sounding, like it's all being run thru a severe bit crush setting. with some projects this happens so severely that the only way to recover them seems to be to start a new session and import all audio data from the previous now corrupted session.
it's been happening since probably like every version of pro tools ever. pretty lame.
Old 11-19-2017, 08:26 PM
Default Re: Bit Crush/Project Crash Bug
Not much chance of any help with zero info on your setup. I haven't heard this on my rigs in several years and several versions
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 11-20-2017, 03:50 AM
climber climber is offline
Never come across this one in 15 years.
Al Hospers
bass, vocal, composer, engineer
CleverSounds Recording
OS X Catalina, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio , PT2020.11, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 11-20-2017, 05:43 AM
Southsidemusic's Avatar
Had this happen on our older Mac Pro computers and we just goto playback engine and choose any other engine and then back again or buffer settings to make it go away. Haven't seen this in the years since we went Trashcan MacPro's and MBP's so maybe its a glitch fromolder OSX.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-20-2017, 08:41 AM
john1192 john1192 is offline
i am not sure the OP is talking about the Glitchy Sound that can be solved by Toggling the PLayback Engine or not .. been holding off replying until the OP gives more info ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 11-20-2017, 10:10 AM
remute remute is offline
If this is what I call the "ring modulation" sound that happened with ever overload warning, the only way to stop it was to uncheck Host Engine: "Ignore errors during playback/record" under Setup: Playback Engine.
Old 11-20-2017, 09:43 PM
it's an error where you first get a CPU dropout and then all audio in the session is sent to bitcrusher hell until you close and reopen it. just a real nuisance to have to keep bothering with that when a project decides to become prone to this glitch.
specs:
MacBook Pro (Retina, 15-inch, Mid 2015)
2.8 GHz Intel Core i7
16 GB 1600 MHz DDR3
AMD Radeon R9 M370X 2048 MB
Pro Tools 12.5.1
Old 11-21-2017, 08:30 AM
specs:
16 GB 1600 MHz DDR3
Pro Tools 12.5.1
see Post #5 .. does this solve your issue ??? toggling PLayback Engine ..
RME BabyFace Pro
RME BabyFace Pro
Old 11-21-2017, 09:13 AM
cshaw cshaw is offline
Yep. Toggle the buffer settings in the playback engine. ex. go from 1024 to 512 and back again. You can do it without having close and reopen the playback window too.
www.chrisshawmix.com
PT 20.3.0
S1
Artist Transport
Avid Control
iPad 7th Gen
HD Native
Hackintosh i9 3.6 GHz Six Core
Apogee Ensemble
OSX 10.13.6
Old 11-21-2017, 06:49 PM
ah ok, yeah, that does seem to work. well toggling the buffer settings occasionally is not too overwhelmingly inconvenient i guess. thanks for the help!
Protools 12.7 crash when trying to open a project from the cloud ilulilu888 Pro Tools 2018 1 02-04-2017 03:41 AM
Corrupt Project file after crash. winvbass Pro Tools TDM Systems (Mac) 0 02-20-2010 04:40 PM
10.5.3 crush joerusi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-29-2008 06:18 PM
Crash (grey screen) on new project. cupofnestor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-24-2006 12:31 AM
Sometimes PT5.3.1 crash when I save project polnetwork.com Pro Tools TDM Systems (Mac) 0 04-09-2003 10:13 AM
