Old 03-05-2017, 02:47 PM
JJTaylor JJTaylor is offline
Default During recording, audio sounds fine, during playback, it sounds bit crushed
This is a truly horrible bug. I have tried everything to fix it as has Avid tech support but no such luck.
You can toggle the buffer size or restart to temporarily get rid of it but it always comes back and the track is useless... it sounds bit crushed like an alien voice.
I'v attached a jpg pic of the waveform before and after this happens (is a sine wave zoomed in). You can't hear it while recording everything sounds fine but when you playback your track is toast.
Any help would be much appreciated. The bug is completely intermittent but happens on a somewhat regular basis.
Joe
Am currently using the following:
Mac: Early 2009 Mac Pro
Processor: 2 x 2.66 GHz Quad Core Intel Xeon
OS version: OS X 10.8.5 (12F45)
RAM: 64 GB 1066 MHz
Hard Drive: 3TB SATA Disk (Operating System Drive), 4TB SATA Disk (For Recording and Playback), 2TB Raid (SSD) SATA (Not in use yet)
Pro Tools version: 11.3.2
Avid Hardware:
2) Avid HD I/O
Pro Tools|HD Native Core PCIe Card
Avid C | 24 Ethernet into port 1
Peripherals: Drobo 5N backup drive into port 2
File Type: jpg Screen Shot - Alien Voice - waveform.jpg (36.7 KB, 0 views)
Old 03-05-2017, 03:37 PM
Default Re: During recording, audio sounds fine, during playback, it sounds bit crushed
Help Us Help You Nobody can offer any advice with zero info
Old 03-05-2017, 03:38 PM
amagras amagras is offline
Hi Joe, what exactly means everything? Did you change the cables of your interface? Also, what interface, etc?
Albee and I were posting at the same time. What he said.
amagrasmusic.com
Old 03-05-2017, 03:47 PM
Am using an Avid HD I/O. By everything I simply mean the audio being tracked
Old 03-05-2017, 03:52 PM
And yes have tried swapping cables..several versions of pro tools...operating systems..hard drives...etc..etc..etc
I started troubleshooting with Avid technicians back in August of 2016
Old 03-05-2017, 04:33 PM
Read this ^^^
amagrasmusic.com
Old 03-05-2017, 11:29 PM
remute remute is offline
I've had this problem since PT 10.
It's quite specific to PT as it doesn't occur for me Live or Logic and changing soundcards etc did nothing to sort it.
The only solution I've found is to turn off:
"Ignore errors during Playback/Record" in the Setup>Playback Engine menu.
You'll, of course then get an error message each and every time there's an engine overload but it's less irritating than the "ring modulation" effect that you had previously.
Joe
RAM: 64 GB 1066 MHz
Avid Hardware:
2) Avid HD I/O
Old 03-06-2017, 11:28 PM
Thanks remute,
Tried it both ways enabling and disabling the "Ignore errors during Playback/Record"...neither worked unfortunately.
Tonight I decided to replace the RAM since changing the buffer size seemed to temporarily stop issue. Feels like I'm grasping but the next step is to replace the computer.
Hopefully I'll have good news tomorrow after testing. (if you leave a track record enabled for a period of time it will trigger the bug).
Old 03-07-2017, 06:09 AM
Thanks remute,
While you're inside the machine do this: clean out all the dust bunnies and reseat ALL connectors and drives. These old cheesegraters Macs can collect dust like nobody's business and connections can go funky all on their own. I just lost one of my right side monitors and what cleared it up was to reseat the audio cable going to it. Nothing had been moved in years - it just decided to stop working.
Old 03-07-2017, 07:25 AM
Originally Posted by musicman691 View Post
WThese old cheesegraters Macs can collect dust like nobody's business and connections can go funky all on their own.
I have a 2009 cheesegrater and it hasn't collected dust. Over 7 years and it is still cleaner than any PC I've ever seen
Hot level but sounds fine?? psdrummin Pro Tools 10 4 03-18-2015 01:17 AM
Playback while recording still sounds laggy The Junt macOS 0 02-21-2012 08:31 AM
Pro TOols playback is OK, system sounds and other sounds won't play bimple Windows 1 08-24-2011 06:14 PM
Plugin sounds fine used as insert, but phasey as aux send Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-15-2008 05:30 AM
PT7.4 Works fine, no sounds from windows though Darryl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2007 11:28 AM
