Old 03-20-2007, 05:55 PM
richsorr richsorr is offline
Default does this make sense??
I would really like to upgrade my converters, I'm not sure I want to spend nearly 3 grand on a Rosetta 800, when the only time I use more then 2 channels is for drums.
My idea is to possibly get a Rosetta 200, and use that for overheads and use my ISA428 (I have the ADC card) for the rest of the drums.
sooo, that said, does this make sense...
Rosetta 200 > Digi 002r via SPDIF
Rosetta 200 > ISA428 via word clock
ISA428 > Digi 002r via ADAT
Digi 002r > Benchmark DAC1 via ADAT out. (maybe)
the rosetta 200s and 428s ins and outs would be set up to a patchbays so i can switch my pres and outboard gear between everything.
Old 03-21-2007, 09:58 AM
Default Re: does this make sense??
guess not?
Old 03-21-2007, 10:07 AM
Park Seward's Avatar
Park Seward Park Seward is offline
It does make scense. Of course you will only be able to get 48kHz to optical via ADAT format. But the Rosetta 200 has S/PDIF so you are good to 96kHz.
The Focusrite unit look nice too with the same sampling rate limits as above.
I don't understand the path Rosetta 200 to the ISA428 to word clock.
You might consider the Lightbridge as a way to attach all these components together:
http://www.m-audio.com/products/en_u...idge-main.html
"The ProFire Lightbridge interfaces up to four Lightpipe devices with a PC or Mac via FireWire—perfect for integrating digital mixers, AD/DA converters and/or ADATs with most popular DAW software."
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 03-21-2007, 12:09 PM
wouldn;t i want the ISA connected to the rosettas word clock if I wanted to use that as the master?
Also, wouldn't I need PT m powered for the lightbridge?
Does this make any sense????? hecatomb MIDI 7 07-09-2007 07:12 AM
Does this make sense to ANYONE? StephenBondy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-08-2006 05:24 PM
Why does this not make sense to me??? TVPostSound Pro Tools TDM Systems (Mac) 2 02-14-2006 06:51 PM
Does this make sense to anyone? landford Post - Surround - Video 1 09-27-2004 05:36 PM
Does this make sense to anyone? gary kleiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-29-2003 04:10 PM
