Old 10-20-2009, 10:09 PM
[email protected] pbb@wn.com.au is offline
Default Possibility of 2 x PC's in tandem?
Is it possible to run LE using 2 x PC's in tandem? If so how might this be done?
ItelRCore 2 x Quad CPU 06600@250GHz
4GB RAM
2 x 500GB HDD
003 factory - Pro Tools LE
Old 10-21-2009, 12:57 AM
Shan's Avatar
Shan Shan is offline
Default Re: Possibility of 2 x PC's in tandem?
I've sync'd up to 002 rigs in the past. It can be done, but quite the bit of work involved. Are you needing more CPU power or I/O?
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-21-2009, 02:23 AM
I'm in the process of buying a new PC with 4GbRAM and was hoping i might be able to use the exisiting rig for additional processing power. Not sure whether it's an option but if so might be a worthwhile measure.
4GB RAM
2 x 500GB HDD
Old 10-21-2009, 03:13 AM
Shan's Avatar
If you upgrade to an i7, it's doubtful you'll need additional processing power. There are a few geeky solutions to use a second computer in PT. I would start first with something like the Vienna Ensemble Pro or REAPER to stream the audio/VI's etc.
Shane
Old 10-21-2009, 03:41 AM
Thanks Shane,
I'll see how the new machine scrubs up when it arrives in a couple of days. Meantime I'll investigate the suggestions.
Thanks again,
Tony.
4GB RAM
2 x 500GB HDD
PT HD 10 - can I use my MBox Pro 3 as an additional tandem AD/DA? DrFord Pro Tools HDX & HD Native Systems (Mac) 3 12-14-2012 08:35 PM
future option possibility??? SteveGam VENUE Live Sound Systems 0 01-04-2007 06:17 AM
ANY possibility with Intel Celeron? dan76 Pro Tools M-Powered (Win) 3 07-09-2006 05:23 PM
best video editing program in tandem with PT? chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-24-2005 07:56 PM
Is this a possibility (vst4) x cabs Tips & Tricks 4 05-02-2001 09:08 AM
