Old 03-18-2024, 10:23 AM
RossH RossH is offline
Default Avid Tape Echo causing noise during Bounce
Hello. I used Avid's Tape Echo plugin for the first time in a music session last week, and when I selected "Bounce Mix" with "Offline" checked, I got blasted with distortion noises until the progress bar finished creating the output file. Very jarring!
I was able to test it today a little more. The loud noise happens with the Tape Echo plugin set to either Native or DSP (I'm on an HDX system). But it doesn't happen if I uncheck 'Offline' bounce and output in real time.
According to Finder, I have version 22.12.0.7 of Tape Echo.aaxplugin installed. I installed the "Eleven_MK_II_2022.12_Mac" installer bundle this morning, it seems that's the newest version available.
PT Prefs 2 says this:
Tape Echo 22.12.0d7 Universal avid 2022-12-09 com.AVID.plugin.Tape Echo /Library/Application Support/Avid/Audio/Plug-Ins/Tape Echo.aaxplugin
I have other tape delay plugins, but I'd expect the Avid one to work. Anyone else have this issue? Thanks.
Specs:
PT Ultimate HDX 2023.3.0
Mac Pro 2012 Intel Xeon
Mojave 10.14.6
BlackMagic DeckLink Intensity Pro
Genelec 5 x 8250A + 7270A DSP Active Subwoofer
Yamaha NS-10's
Control Room: PT Ultimate HDX 2023.3.0 // Mac Pro 2012 // Mojave 10.14.6 // BlackMagic DeckLink Intensity Pro // Genelec 5 x 8250A + 7270A DSP Active Subwoofer // Yamaha NS-10's
Edit Suite: PT Ultimate 2023.12.1 // Mac Pro 2013 // Monterey 12.7.3 // Focusrite 18i20 // Genelec 5 x 6010A + 5040A Active Subwoofer
Video Suite: PT Ultimate 2023.12.1 // iMac Pro 2017 //Monterey 12.7.3 // Focusrite Scarlett Solo
Old 03-18-2024, 11:25 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Avid Tape Echo causing noise during Bounce
Humm I use Tape Echo all the time but admittedly I only do real time bounce
So as they say on TV --I can neither confirm or deny
I will be curious to see what develops
System :
Enjoy the Journey
.... Kev...
Old 03-18-2024, 01:02 PM
Never seen this, but I don't have HDX. I would do troubleshooting. Does it happen with non-HDX playback engine? Wappen if all other plugins are removed? etc.
Kinda weird that this is causing noise when offline bounce should not be generating anything audible and AFAIK Pro Tools output should be muted. Is the bounced file created OK?
Old 03-18-2024, 02:29 PM
The bounced file is ok, the noise is not included in the output file, I forgot to mention that. Good suggestions, I will try them and report back.
HTML code is On
Avid Studio Reverb and Tape Echo matthewmkb AAX Plug-ins 4 11-02-2017 04:52 PM
Clip slide causing echo ? [solved] K Roche Pro Tools 12 4 02-04-2016 10:03 AM
Tape One released : tape delay by Noise Makers Noise Makers AAX Plug-ins 4 01-05-2016 01:57 AM
Fulltone Tube Tape Echo for vocals? Dag Haavimb Pro Tools TDM Systems (Mac) 1 06-27-2005 09:05 AM
Fulltone Tube Tape Echo for vocals? Dag Haavimb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-27-2005 06:21 AM
