Old 01-16-2009, 04:03 AM
ruffsense ruffsense is offline
Default M-audio keystation 49e
How do i get my midi controller to work in pro tools le 8.
It is connect by midi and not by USB.
Can someone help me out?
Old 01-16-2009, 04:36 AM
danander11 danander11 is offline
Default Re: M-audio keystation 49e
I supose it would depend on your interface. Although there are a few possible ways of doing it, I connect mine via the midi line-in on the back of my 003.
It works great that way... If you do not have a midi-in on your interface, you would have to find a way of doing that, or just use the USB. I used USB for over a year without any problems. I just decided to try something different when I got my 003.
Once you have it connected, start PT, open SETUP (on th menu bar), select MIDI, then select INPUT DEVICES. Make sure that your 49e is checked and you should be good to go.
Hope this helps..
Peace!
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 01-16-2009, 04:53 AM
Hope this helps..
Peace!
I got a 002 rack and mine is also connected with midi line-in.
Old 01-16-2009, 05:00 AM
Cool, Just go through the setup routine then and you should be set.
I plugged mine in via the midiport and when I fired the 003 up for the first time, there it was. I never had to do anything else.
Peace!
Here I am,
Hobo Shave!
m-audio keystation 49e chalkoutline MIDI 21 01-31-2007 05:06 PM
Plz help me with my M Audio Keystation 49 youngd478 MIDI 0 01-20-2007 04:08 PM
M-Audio Keystation Pro 88 JSK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-30-2006 08:39 PM
M-audio keystation 49e Palli-Moon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-16-2005 07:24 AM
M Audio Keystation 88 Pro Michael KaY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2004 01:08 PM
