Old 04-08-2016, 07:18 AM
pinkyf
Guest
Posts: n/a
Default audio playback problems with 002r/cubase8.5
Hello everybody,
I got a big problem with playing back audio in Cubase 8.5.
I even contacted Steinberg three weeks ago but since now nobody has answered me.
When I play back audio in Cubase 8.5 the audio is clicking.
This is just a playback problem. The Audio is recorded and even exported correctly.
I've changed Audio setups (screenshot1) and changed the buffer size. Even with highest buffersize it clicks like hell.
I've tried the following drivers:
-Driver from my Pro Tools 9.0 CD-Rom
-standalone Windows Audio drivers v7.4 (does not work at all. Windows doesn't recognise Interface)
-standalone Windows Audio drivers v8.0.3 (does not work at all. Windows doesn't recognise Interface)
-standalone Windows Audio drivers v9.0.8 (does not work at all. Windows doesn't recognise Interface)
-Latest drivers for 003Rack version 9.0.8
The problem does not occure, when I'm in the Audiomode (where I can edit the Audio) and press the "PLAY"-Button on the top.(screenshot2)
Also everything is fine, if I select the generic low latency ASIO driver.
My setup:
Intel(R) Core(TM) i7-6700 CPU @3,40GHz 3,41 GHz
RAM 8GB
Digi 002 (now latest driver 9.0.8 installed)
Windows 10 Home 64bit (updated)
CSL PCIe Controller Firewire Card
Cubase 8.5.15 (latest version)
With my previous setup (Macbook, OSX Lion, DIGI002, Cubase 8.5)) I had the same problems, that's why I have a new computer now.
Has anyone any suggestions what to do?
It's driving me mad.
Si Soft Sandra Data:
SiSoftware Sandra
Nr
Hostname : DESKTOP-C46KVJN
Arbeitsgruppe : WORKGROUP
System
Modell : MEDION Akoya P5029 D/C119
Serialnummer : 1C11901*******
Gehäuse : MEDION Desktop
Mainboard : MEDION H110H4-EM
Serialnummer : KS2405G********
System BIOS : AMI (OEM) 110EMW0X.101 11/20/2015
Intel vPro : 11.00.00.1173
Gesamtspeicher : 8GB DIMM DDR4
Prozessor(en)
Prozessor : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (4C 8T 3.81GHz/4GHz, 3.8GHz IMC/4GHz, 4x 256kB L2, 8MB L3)
Chipsatz
Speichercontroller : ECS Core (Skylake-D QC) Host Bridge/DRAM Registers 100MHz, 8GB DIMM DDR4 2.13GHz 64-bit, Interne Grafikeinheit
Speichermodul(e)
Speichermodul : Samsung M378A1G43DB0-CPB 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-51-16-5)
Grafiksystem
Monitor : Samsung SyncMaster
(1440x900, 19.1")
Grafikkarte : Intel(R) HD Graphics 530 (24CU 192SP SM5.2 1.15GHz, 768kB L2, 128MB DDR4 2.13GHz 64-bit, Interne Grafikeinheit)
Grafikprozessor
OpenCL GP-Prozessor : Intel(R) HD Graphics 530 (192SP 24C 1.15GHz, 512kB L2, 3.2GB DDR4 2.13GHz 64-bit, Interne Grafikeinheit)
Compute Shader Prozessor : Intel(R) HD Graphics 530 (192SP 24C 1.15GHz, 768kB L2, 128MB DDR4 2.13GHz 64-bit, Interne Grafikeinheit)
OpenGL Prozessor : Intel(R) HD Graphics 530 (192SP 24C 1GHz/1.15GHz, 768kB L2, 128MB DDR4 2.13GHz 64-bit, Interne Grafikeinheit)
Physische Speichergeräte
Samsung SSD 850 EVO 500GB (500.1GB, SATA600, 2.5", SSD, SED) : 466GB (C:)
WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D:) (F:)
Generic- Multi-Card (USB2) : k.A. (G:)
TSSTcorp CDDVDW SH-216FB (SATA150, DVD+-RW, CD-RW) : k.A. (E:)
Logischer Speichergeräte
Festplatte (C:) : 465GB (NTFS, 4kB) @ Samsung SSD 850 EVO 500GB (500.1GB, SATA600, 2.5", SSD, SED)
BACKUPSYSTEM (D:) : 488GB (NTFS, 4kB) @ WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm)
CUBASE (F:) : 443GB (NTFS, 4kB) @ WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm)
Wiederherstellung : 450MB (NTFS, 4kB) @ Samsung SSD 850 EVO 500GB (500.1GB, SATA600, 2.5", SSD, SED)
Auswechselbares Laufwerk (G:) : k.A. @ Generic- Multi-Card (USB2)
CD-ROM/DVD (E:) : k.A. @ TSSTcorp CDDVDW SH-216FB (SATA150, DVD+-RW, CD-RW)
Peripherie
LPC Hub Controller 1 : ECS Sunrise Point-H LPC Controller
LPC Legacy Controller 1 : T2 86-25
Audio Gerät : ECS Sunrise Point-H HD Audio
Audio Codec : Realtek Semi Realtek 662 High Definition Audio
Laufwerkscontroller : ECS Sunrise Point-H SATA controller [AHCI mode]
Laufwerkscontroller : ECS Sunrise Point-H PMC
USB Controller 1 : ECS Sunrise Point-H USB 3.0 xHCI Controller
FireWire/1394 Controller 1 : VIA VT6315 Series Firewire Controller
System SMBus Controller 1 : Intel ICH SMBus
Drucker- und Faxgeräte
Drucker : Microsoft XPS Document Writer v4 (600x600, Farbwiedergabe)
Drucker : Microsoft Print To PDF (600x600, Farbwiedergabe)
Peripherie
Media Player : WDC WD10EZEX-00BN5A0 (443.23GB)
Media Player : WDC WD10EZEX-00BN5A0 (488.28GB)
Netzwerkdienste
Netzwerkadapter : Realtek PCIe GBE Family Controller (Ethernet)
Netzwerkadapter : Bluetooth Device (Personal Area Network) (Ethernet)
Drahtlosadapter : Realtek RTL8723B Wireless LAN 802.11n USB 2.0 Network Adapter (802.11n (HT), AES-CCMP, 102Mbps)
Betriebssystem
Windowssystem : Microsoft Windows 10 Privat 10.00.10586
Kompatibel mit Plattform : x64
Old 04-08-2016, 04:06 PM
Default Re: audio playback problems with 002r/cubase8.5
This could be the problem as VIA firewire controllers are often a show-stopper for audio. Around $50 will get you a proper card with a TI chipset.
Beyond that, why hang onto a piece of hardware that is:
A-old technology and not very good
B-no longer supported
C-can be outclassed by most any current hardware over $400(a used 003r at $250-300 is even a step up)
another tip; set Windows to use the motherboard's audio so that your DAW doesn't have to compete for control of the interface
Old 04-09-2016, 01:53 AM
pinkyf
Guest
Posts: n/a
Hey albee1952,
thanks for your help.
Any recommendation which firewirecard to use? (model, manufacturer?)
My question:
Why is playback in Windows and in Cubase Audioeditwindow possible, but in the arrangement window it isn't?
I mean: The interface is able to playback audio without noises. Only in arrangementwindow those clicks occur.
Doesn't that mean, that the firewirecard is fine?
To your questions:
I use my old digi002, cause I don't have no money anymore.
I wanted to run cubase on my mac, but it did'nt work out so I had to buy a new PC. I'm totaly broke right now but will for sure get a new interface in winter.
Thanks for your help.
Old 04-09-2016, 03:44 AM
pinkyf
Guest
Posts: n/a
Correct me if I'm wrong, but in my opinion the error could be something else, since I've had the same problem with my Mac (Windows 7) and Cubase 8.5
So it isn't neccessary my new firewirecard in my PC, am I right?
To be precise:
Problem occurs with each setup.
Macbook (internal firewireslot)
Windows 7
and
PC (CSL PCIe Controller Firewire Card)
Windows 10
Old 04-09-2016, 04:12 PM
Well, if it doesn't work on the MacBook either, are you informed about the old "power harness" issue that plagues almost all 002's? Then, if you are still looking for a FW card, you must first figure out what kind of open slot your computer has(PCI or PCIe). Then look at the brand SIIG as they use TI chips on many of their cards(but not all). But if the 002 is bad, there is no reason to buy a card(yet). Plenty of USB interfaces from MOTU and Focusrite
Old 04-10-2016, 07:40 AM
pinkyf
Guest
Posts: n/a
Yes, I know the power harness issue, but my digi002 is fine because ProTools 9 on my Macbook is working without problems.
I'm afraid that I get the same problem with a different Firewirecard, because the problem occurs on MacBook Windows 7 and PC Windows 10.
What should I do?
Old 04-13-2016, 06:49 AM
pinkyf
Guest
Posts: n/a
Update:
1st:
I started Cubase in "Safe Start Mode" which sets everything to default when starting. Cubaseproblem still exists. That means, that it has nothing to do with my settings.
2nd:
In my bios I disabled the following:
-Hyperthreading
-EIST
-CPU C-States
3rd:
I installed Pro Tools 9 on my PC. Pro Tools works fine!!!
4th:
I imported Audio into Cubase
PLEASE HELP!!!!
Old 04-20-2016, 03:09 AM
pinkyf
Guest
Posts: n/a
Update:
5th:
I closed all programs/apps/processes in task manager which are not neccessary for running Windows 10.
What information is missing to solve my problem?
Old 05-03-2016, 04:18 AM
pinkyf
Guest
Posts: n/a
Update:
6th
Installed different interface (Traktor Control S2) with latest drivers:
No problems
Tried the Generic Low Laterncy Asio with internal soundcard:
No problems
Digi002 problem still exists.
Old 05-10-2016, 06:38 AM
pinkyf
Guest
Posts: n/a
Update
7th:
Have found, that "shared memory" can cause problems. Found out that in BIOS Chipset-SystemAgentConfiguration there are entries called IGD Memory 32M and DVMT Memory 256M. Are those relevant entries for "shared memory"?
If yes, I can not imagine if it has any influence on my performace (Those are less than 300mb total). Since I really don't know what those entries mean, I was too scared to change them. If anyone can tell me if I can change them without damaging my computer i will do so.
Does the hd graphics 530 have "shared memory"?
Couldn't find anything.
002r and Cubase - Distorted Audio Playback 1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-15-2013 06:35 AM
Digi 002r audio manager problems. Matmorfus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-12-2008 03:55 PM
Audio Skips on Playback using 002r, any ideas? gibson_sg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-28-2005 12:50 PM
OS X system audio playback through 002R? Bendrissa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-28-2004 05:45 AM
G5 audio problems with Digi 002r volts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-28-2004 11:50 AM
