Expansion Pack Question
I have an IMac 10.7.7 with the 11R as my only interface with PT 10. I believe that I did not get the expansion pack even though it was stated so on the box that I purchased. My 11R version states 1.0.3. As far as I can see Avid states that the Expansion Pack is only compatible with Mac OS X 10.6.6 - 10.6.7. Is the reason I don't see it on my 11R screen is because of my OS? Makes no sense.
Second question, I assume I would be able to see the Expansion pack extras on the 11R window on the unit itself correct? Or would I only see them in the editor window when I launch it through PT?
2020 Mac Mini I7 3.2GHz, 36 GB Ram, Catalina, ProTools 2018.12.0 UAudio X6, Axiom Pro S49 MkII, Maschine MKIII. |
Re: Expansion Pack Question
This is just a shot in the dark, but have you registered PT yet? If so, log into the Avid site and look under "My Software" or "My Downloads" or something like that. The EXP may be there ready and waiting to be downloaded.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Just wondering, was the ERXP supposed to be pre-installed on the unit or did you buy the ERXP? Was this a unit that was sold with PT9 or 10?
If the unit was SAID to include the ERXP, then it would have been pre-installed. If your firmware version is showing 1.0.3 then you do not have the ERXP installed on the unit itself. So in that case, if the ERXP was supposed to be pre-installed, you need to call or email Avid. They can verify the 11R registered to your account and then issue you a S/N and ID code so you can install the ERXP on the 11R unit. If you are running PT 10.2? (i think) then the new UI files should already be included, if they are not or if you run an older version of PT just follow the instructions in the link above.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Expansion Pack Question.. | 11rpro | General Discussion | 10 | 05-12-2012 07:46 PM |
'nother Expansion Pack question | derker | Eleven Rack | 15 | 03-07-2011 07:54 AM |
Expansion Pack rigs question | mikefont | Eleven Rack | 6 | 02-10-2011 02:48 PM |
Question about Instrument Expansion Pack | Bambison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-31-2011 04:38 PM |
Instrument Expansion Pack Question | Mattafact | Pro Tools 9 | 1 | 11-12-2010 04:38 PM |
