Old 05-12-2002, 01:10 PM
mattm mattm is offline
Default Re: Can you run PTLE without the Breakout Box???
Originally posted by Rock_Artist:
But won't PT freeze @ the DAE stage?
Havn't tried it yet...
<font size="2" face="Verdana, Arial">only with TDM. it does give you the option to quit or turn the hardware on before you click OK to continue loading. it will either quit or freeze if you click OK without the hardware turned on/connected but that's not really surprising, right?
the PTLE "hardware" is on the PCI card so weather the external "hardware" is connected or not makes no difference.
~matt
Old 05-12-2002, 01:59 PM
Bastiaan Bastiaan is offline
True. I was forced to work like that for some time since i bought my digi001 second-hand without a cable. I was able to use the adat instead, together with my blackface adat for a/d conversion.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 05-13-2002, 12:12 AM
Datus Datus is offline
Default Can you run PTLE without the Breakout Box???
I have been contemplating better ways to use Pro Tools live. I got a new digital mixer and am going to get the expansion card to allow adat in and out, and was thinking it would be nice to run any audio out of protools throught the adats when I use it live. At that point I would have no need for the breakout box. I have yet to try this and was curious if you can run ptle, and have the lightpipes function on the card without the breakout box connected? Anyone know?
Stephen Tyler
Old 05-13-2002, 12:23 AM
the "box" doesn't need to be connected for the light pipes to work.
Old 05-13-2002, 12:30 AM
Rock_Artist Rock_Artist is offline
Just wanna do music,
RA.
Old 05-13-2002, 12:42 AM
as long as the PCI card is correctly installed, PTLE will run without a hitch.
Old 05-13-2002, 12:49 AM
Thanks for the info matt..
Stephen Tyler
PCI Breakout box and the G5 poppo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-25-2003 01:24 PM
does 001 work without the breakout box? kmshroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-01-2003 07:54 AM
please help with breakout box prob agent fu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-19-2003 03:33 AM
Breakout Cable gerax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-06-2001 06:52 AM
888 to 01V 25pin to AES-EBU breakout box Tips & Tricks 0 10-08-1999 11:54 PM
