  #1311
Old 06-29-2008, 11:44 AM
mykhal c's Avatar
mykhal c mykhal c is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
I have seen Memset, although never used it as these modern mobo's have OC profiles you can save a good working OC to. So I generally do my calculations with a calculator, dial it in the BIOS and see if it POST's. If it POST's correctly and I get to the desktop I then torture (Prime 95) it for a bit to see if it's stable. If it's stable with all 4 cores at 100% then I'll do some benches to see where its at.
yeah with the P5K Deluxe and my 0603 bios there are limitations with what secondary timings could be adjusted. so i had to rely on what was bein' adjusted automatically in some cases. this is where MEMSET helped me the most...on the ones i could NOT adjust. anyway, lemme know what ya think
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #1312
Old 06-29-2008, 05:34 PM
mano111 mano111 is offline
I'm excited about the 4800 series and will be buying a 4850/70 very soon.
I just built a system for a freind a few days ago with 4850/Q9450. Its a very good gamers card, plays Unreal 3 at 1900*1200 really smooth at 60+ fps with 4*AA . It gets hot so maybe an Arctic Cooling accelero S1 would be a good idea if you get it for a system that is supposed to be cool and quiet.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #1313
Old 06-29-2008, 07:29 PM
sunburst79 sunburst79 is offline
I just built a system for a friend a few days ago with 4850/Q9450. Its a very good gamers card, plays Unreal 3 at 1900*1200 really smooth at 60+ fps with 4*AA . It gets hot so maybe an Arctic Cooling accelero S1 would be a good idea if you get it for a system that is supposed to be cool and quiet.
Yeah I'm leaning towards the 4850 as My ThermalRight V2 passive cooler should fit it. The same coolers fit the X1050,X1600, X3850 and X4850. This would be going into my P5B Deluxe WiFi/Q6600 desktop. Apparently there is a PHYSX "Patch" out there to let them run the AGEIA code. I'm not a gamer but 60FPS is the magic number and 1900*1200 is a fairly high resolution for running eye candy.
3 Days ago? you got a early card pretty quick. Nice to see a non paper launch for a change also.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #1314
Old 06-30-2008, 01:55 PM
pihahiroth's Avatar
pihahiroth pihahiroth is offline
Default AUDIO CONFIG.
HI There!!
I just started to use my Mbox 2 Pro yesterday and I´ve got a problem with monitors.
I have the KRK RP-8 and I already made the conections, Right Monitor to the MON OUT RIGHT, and Left Monitor to the MON OUT LEFT output of the Mbox.
I can hear what I record, buy I also listen interference noises even some windows interference noises.
I don´t understand what happen.. I already configure the Mbox as the playback default device, is it that right??
Please some help on how to config the Audio Output on Pro Tools!!! Thanks a lot
Dont Stop for Nothing, its full speed or Nothing!
  #1315
Old 06-30-2008, 04:12 PM
Default Re: AUDIO CONFIG.
first, not being rude but please post this in the correct thread for this kind of a post!!!
second, 2 things, you say interferance noises which is kinda vague. do you mean bleeps and blips and sound from windows, or do you mean like static and ground hum?? not sure from your post.
please move this post out of this thread and into the main pt le for windows.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
  #1316
Old 07-01-2008, 01:16 AM
mykhal c's Avatar
At the moment I'm pretty sure I've seen a FSB wall (at around 460-470 and I don't want to pump more than 1.51V on the NB or more than 2.12V on the DRAM)
blade, do you manually set the voltage on the NB??? i've got all my voltages set to 'AUTO' except cpu and dram. what do you recommend?? thanks
  #1317
Old 07-01-2008, 05:29 AM
bladesg bladesg is offline
Yes I manually set voltages to the NB and South Bridge. I wouldn't go for more than 1.55 on the NB and no more than 1.5 on the SB.
  #1318
Old 07-01-2008, 10:54 AM
mykhal c's Avatar
thanks man. is there a tool that you use that displays the current voltages of one's mobo???
also, pls list your specs so i can post your build on page 1. thanks
  #1319
Old 07-02-2008, 01:21 AM
Everest will list voltages.
My system specs:
Asus Mongrel Formula SE X38 (Maximus Formula SE with Rampage Formula 0403 BIOS)
Q6600 G0 SLACR - Noctua NH-U12P
2Gb Mushkin XP2-8500
512Mb BFG Geforce 8800GT OC (G92)
ADS Pyro 64 (onboard firewire does work too)
Pioneer 215 DVD-RW - SATA
Corsair HX520
WD 74Gb Raptor (OS)/WD 500Gb AAKS/Seagate 320Gb/ WD 200Gb - All SATA
Win XP Pro SP3 - PT LE 7.4cs5/MP Toolkit/Digi 003R
  #1320
Old 07-02-2008, 05:36 AM
The Bad Dawg DAW
Scott
Core 2 Specs Page
i7 Builds - Specs and Results mykhal c Windows 6784 10-17-2019 10:56 PM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 06:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 03:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 03:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 07:51 PM
