Copying and pasting panning automation
When composing I quite often have a stereo sound source moving from left speaker to right. When I do this I find I cant copy and paste the left channel pan automation to the right channel . Is there anyway of doing this? Thanks in advance, Mike. |
Re: Copying and pasting panning automation
paste special command I think.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
Paste special will do.
But: is there a known trick to Paste Reversed? So that if I have drawn an automation for left channel going for example from left to right I could copy it and paste to the right channel in way that would make it going from right to left? |
Would it be more efficient to have your L&R on a stereo track so the Pan function would work as a balance control and you would only need to address a single function instead of matching 2 functions with opposite intentions?
Track View : Left Pan --> Copy
Track View : Right Pan --> Cmd + Ctrl + V (paste an automation to a "foreign"/different-type - paramter) |
Thanks so much for this. It was still useful in 2017, with Pro Tools 12. I'm posting because of a conflict I found: Turns out that Evernote was swallowing up ctrl-cmd-v. So if it doesn't work, try checking for other apps that are heavy on key shortcuts.
-- Craig Good Teller of stories, some of them true. |
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU !!!!!!!!!!!!!!!!! ... wanted to copy audio track pan automation to aux send ... you can also cmd+c from audio track and cmd+ctrl+v to auxilary (pan mode on both of course) |
Copying and pasting regions | wgouldsby | General Discussion | 2 | 01-14-2013 03:14 AM |
problem copying and pasting | killionaire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-30-2009 12:07 AM |
copying and pasting regions | andydunham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-29-2008 09:16 AM |
Copying and pasting in the workspace | meathman | Post - Surround - Video | 0 | 07-14-2007 12:08 PM |
Looping and copying and pasting | Mikchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-17-2003 08:53 AM |
