External Instruments and One midi Controller help!
Okay I have a bunch of racks, and some old analog gear, however I have a Virus TI to control everything. I don't know how to properly set this up. I have midi ins from my racks gear going into my Motu midiexpress XT out. Then I have my virus ti going in and out into my XT, because I want to use the virus TI to control EVERYTHING. How do I do this correctly! I am very confused. Thanks
Re: External Instruments and One midi Controller help!
Then the main difference is that you will want to "sever" the internal MIDI connection in the Virus that connects the actual keys to the sound module. I have no idea what terminology Access uses but I am mostly familiar with it being called "local control" and you will want to turn local control off. Now when you play the keys, it will only send MIDI to the MIDI output, it will not trigger the virus directly. the virus' synth will only respond to MIDI coming in from the MIDI inputs. Next, you need a MIDI track ( or an instrument track ) for every synth, including the virus, that you want to trigger and record MIDI for. If your synth(s) is/are multi-timbral then you might need multiple midi tracks, one per MIDI-channel/patch (basic MIDI stuff) Leave the MIDI input selectors set to any. Set the MIDI output selectors to the specific synths and channels that you intend to trigger. MIDI Thru needs to be checked in the options menu. You don't say if you are on Mac or PC but having MIDI Studio set up with your named MIDI instruments makes choosing outputs and channels much easier.. You will also, presumably, need to add aux inputs (or instrument tracks) to monitor the synths or audio tracks to record the audio… You select which synth you want to "play" by highlighting it's MIDI track, or by record-enabling a track you are ready to put down. There are some more specific options for how this works in the MIDI preferences.. That's the basic outline. If this is not making sense, then I suspect you are not very familiar with ProTools tracks and how they are used. In that case it is hard to know where to start..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Virtual Instruments and MIDI Controller questions | Simba | MIDI | 3 | 01-29-2011 06:27 PM |
Switching virtual instruments with MIDI controller | negrelja | MIDI | 2 | 01-20-2011 02:22 PM |
saving MIDI controller setups with Virtual Instruments... | Chief Pronto | Virtual Instruments | 2 | 07-20-2009 08:05 PM |
Automating Plugin Instruments With Midi Controller.....whats wrong here? | bcarey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-23-2009 09:40 AM |
Mapping Creative Collection instruments to MIDI controller | GreatCthulhu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-29-2008 07:28 AM |
