Record fader issue
Why does the record fader effect the playback channel on a track. I would think that in terms of the playback being a return and it should not be effected by the record channel. There would be no need for a software monitoring option (requested by users in the past). I should be able to reduce the record fader to -inf and not hear that channel's input but still hear the playback or return channel. Can anyone explain how the ball got drop on this one? If this is a correct function, then explain the ability to separate record and playback faders in preferences?
Re: Record fader
I don't follow. What's a record fader? Each track has a fader that controls that track's output to the mix bus, or whatever bus it's assigned to. If you put an audio track into record and pull its fader down all the way, you shouldn't hear the input. Are you experiencing something different in that regard?
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Re: Record fader
There is a pref called 'unlink record & playback faders'.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Re: Record fader
Re: Record fader
Re: Record fader
I have the faders unlnked and the record fader still reduces the playback level.
Re: Record fader
Re: Record fader
Re: Record fader
Re: Record fader
Audio malfunction/midi malfunction | Atomicroaddaddy | macOS | 1 | 10-10-2012 05:59 AM |
Master fader won't record automation when in "write" mode? | JAZZ27 | Pro Tools TDM Systems (Mac) | 2 | 04-19-2008 07:23 AM |
Deleted master fader, now can't record | carlg1212 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-22-2007 02:06 PM |
Mix It Like a Record "crashes" fader | Naagzh | Tips & Tricks | 4 | 02-14-2007 08:33 AM |
Using the Fader in Record mode | brianpatrick | General Discussion | 8 | 04-01-2001 03:26 PM |
