Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 09-22-2022, 06:08 AM
CATH88 CATH88 is offline
Default My RODE USB microphone not recognized by Pro Tools First
Hello, I am new here.
Before switching to Pro Tools, I just installed Pro Tools First to see.
I have a RODE NT USB microphone. This microphone does not have a sound card, the software does not recognize an input. However, my microphone is well checked in my hardware configuration like the attached image.
Can anyone help me?
I'm on iMac Retina 5K, 27-inch, 2017, macOS Montorey 12.6, 4.2 GHz Intel Core i7 quad-core processor, 16 GB 2400 MHz DDR4 memory.
Thanks
File Type: jpg Capture d’écran 2022-09-22 à 14.26.10.jpg (40.1 KB, 0 views)
Old 09-22-2022, 06:59 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: My RODE USB microphone not recognized by Pro Tools First
Pro Tools First has been discontinued for a while now, is a few versions behind and also had limited input/output capabilities. If you really want to try out Pro Tools, I would suggest the 30-day trial, which will give you a better idea of what the software can do.
You could also just do a one month subscription to Pro Tools Artist, which would be $10.00 and you can either not renew if it's not for you, or renew the subscription if it works out.
Will
System Details
Old 09-22-2022, 07:00 AM
smurfyou smurfyou is offline
Je suis désolé, mon français n'est pas bon.
I am not familiar with Pro Tools First. But I would suggest looking at the "Pro Tools Aggregate I/O" in your Audio Devices window. Ensure the Rode Entree and Sortie are both listed within the Aggregate.
Then in Pro Tools set your playback engine as the Pro Tools Aggregate. After that you can should be able to open the I/O Setup window and see the input from the Rode.
~Will
Old 09-23-2022, 06:29 AM
Thanks a lot.
It worked. My problem is solved
Pro Tools 12 and Rode NT-USB Microphone? (Help) spooner_von_nobody Pro Tools 12 4 11-22-2019 06:34 AM
Fast Track Solo And Rode NT1-A Microphone Problem Mechacaseal FireWire & USB Audio Interfaces (Win) 11 12-09-2015 09:38 AM
Focusrite 18i20 Pre amp with a Rode K2 and Nt1a microphone Kollen.col Third Party Interfaces 6 11-22-2013 04:38 AM
USB Microphone and other Audio devices not recognized El Cuervo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-05-2010 09:33 PM
Rode Microphone (The Less Expensive One) Sounder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-03-2000 04:55 PM
