Old 12-02-2014, 07:56 AM
tooold's Avatar
tooold tooold is offline
Default Edit window moves on selecting clip
This is a strange one, and a little hard to describe. I use a dual-monitor setup, driving one monitor from the HDMI out on my 2011 Mac Mini Server (running 10.9.4), and the other from the Thunderbolt output.
When I'm working in the edit window spread across two displays, if I click on a clip that's anywhere near the inner boundaries of either of the two monitors, the display changes horizontal position. At first, I thought it was to make the entire clip visible on one screen, but it will also span the boundary between the two screens with the selected clip. Once I've clicked on one clip in a track, clicking on other clips in that track doesn't move the display, but if I click on another clip in another track, it does it again. It used not to do this.
I know there are a number of strange display behaviors in Mavericks - could this be one of them? It's not lethal, but it's disorienting when I'm focused on doing an edit and things start moving around. I've looked in System Prefs as well as PT prefs for a likely culprit, but I can't see anything that would make sense.
Any ideas?
Thanks,
Myles
System 1: 2023 Mac Studio 64Gb RAM, OS 13.6, PT Native 2023.12, Metric Halo ULN-8, LIO
System 2: 2021 M1 Mini 16Gb, OS 13.6, Native 2023.9, MH ULN-8 4d
http://www.mylescochran.com
Old 12-02-2014, 08:06 AM
Default Re: Edit window moves on selecting clip
It may be the way OSX handles spreading a window across 2 screens, I don't really know. For me, when I tried having the EDIT window across 2 screens, the bezel in the middle drove me nuts. Now I leave the EDIT window on one screen only and am much happier. What happens if you confine the EDIT window to a single screen? What size screens are you running(and are they operating at each screen's native resolution)?
Old 12-02-2014, 09:25 AM
tooold's Avatar
Hi Dave -
They're dual 24" Samsungs operating at native resolution. The only reason I'm thinking it's a PT thing is the behavior based on changing tracks.
I've gotten used to the gap between the two screens - it sort of vanishes after a while.
Old 12-02-2014, 12:13 PM
tooold's Avatar
I found it - "zoom toggle follows edit selection" on the editing preferences tab.
Back to work...
Myles
show clip name in edit window browniespeaks Windows 2 05-11-2020 04:05 PM
edit window not showing clip on a meters dmitri85 Pro Tools 11 9 10-25-2014 03:03 PM
Clip indicators in edit window P_J Pro Tools 11 4 10-17-2013 05:40 PM
Edit window not in foreground when a clip is highlighted! Herokazz Windows 0 04-14-2012 08:57 AM
Selecting in regions list doesn't select in edit window peytontodd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-15-2011 02:33 PM
