Old 04-14-2012, 08:57 AM
Herokazz Herokazz is offline
Default Edit window not in foreground when a clip is highlighted!
This is a very annoying bug that is destroying work flow completely!
When I highlight a clip or when it is highlighted, after I trimmed it for example, the edit window is no longer in the foreground. That means i cant use my short cut keys before I click somewhere in the session un-highlighting the clip.
Example: If I want to undo a trim, I have to place the cursor somewhere in the session where no clips are highlighted, bringing the edit window back to the foreground again, before I can pres "z" to undo.
This was an issue in 10.0, NOT an issue in 10.0.1, now it is an issue again in 10.1.2!
Anyone else seeing this??
show clip name in edit window browniespeaks Windows 2 05-11-2020 04:05 PM
edit window not showing clip on a meters dmitri85 Pro Tools 11 9 10-25-2014 03:03 PM
Yellow highlighted tracks in edit window? tdblanchard macOS 3 03-15-2014 06:43 PM
Clip indicators in edit window P_J Pro Tools 11 4 10-17-2013 05:40 PM
"Stop" or "Play" puts edit window in foreground mahler007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2005 01:32 PM
