ProTools 9 is still saying it cannot find any digidesign hardware.
Hi folks. Need a bit of help here.
Just installed PT9 crossgrade. Got my iLok and my license on it, inputted the serial code from my digi002 rack and got through all those stages. When I try load up PT9 it says it cannot locate digidesign hardware. Why is this happening?! I thought PT9 did not require any official hardware?! This has been an extremely long process; backing up old sessions, putting Windows 7 on a partitioned drive with PT9 installed onto it. Any help would be great. Thanks, |
Re: ProTools 9 is still saying it cannot find any digidesign hardware.
When you uninstalled PT 8 or your previous version, did you use the Avid uninstaller (or Digi), or Windows uninstaller? You may have to go in and bomb the rest of the PT files other than your sessions because sometimes all of the old files don't get removed.
Or does the installation of the crossgrade require it sees the previous version? I don't know. I think this is the drive issue they've been talking about in the PT 9 section.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) Last edited by Julia B; 01-22-2011 at 11:22 AM. Reason: added possible driver issue |
Another thing you can try is.... you have 30 days free telephone tech support IIRC. Use it. I think if you call them around 8:00 pm your time you'll catch them. Try via Skype or something like that so it doesn't cost you. At least you have the luxury of the support staff speaking English.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Hiya.
About two seconds after I posted this I worked out the problem. It wasn't asking for digidesign hardware but any hardware. It appears that only Mac can run off the onboard soundcard (Core Audio) whereas I need some interface attached for working with windows. If this isn't the case and I can run PT9 using my onboard laptop soundcard I would love to know how. As it stands I am waiting on a macbook pro as my system is not suitable for running large sessions. Thanks anyway Julia, b |
Unable to find Digidesign Hardware | Mike De | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-16-2010 02:59 PM |
cant find digidesign hardware | krem2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-03-2009 11:47 PM |
Pro Tools can't find Digidesign hardware? | Doctor M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-23-2008 09:47 PM |
Can't Find Digidesign Hardware error? | CStern | Pro Tools TDM Systems (Mac) | 24 | 07-28-2005 08:30 AM |
unable to find digidesign hardware | scottdarry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-08-2005 08:14 PM |
