What AGP graphics card for 2 X 21\"?
I am going to get one of the new G4 AGP Macs (533 MP or 733), since I have two 21" monitors I wonder what AGP graphics cards I have to choose from?
IMHO the Appian Jeronimo 2000 doesn't have enough RAM for two 21" (running thousands of colours at 1152 x 870), does it? |
Re: What AGP graphics card for 2 X 21\"?
Hello??
Hello John
I´m running the Appian card with thousands of colours at 1280 x 1024 with no problem. Regards Wolfgang ------------------ Wolfgang Eller SRS Mastering/Germany WWW.SRS-Mastering.de [email protected]
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
promax have a monitor card that does the trick! 2 monitorconnectors on one agp card, espeacially designed for g4's.
it's a rebuild matrox-millenium i think. and...it's cheap!! ($299) called promax dh-max (dualhead) so you can throw out your build in card without losing a thougth on it |
RMO hi man i use the DH-MAX with PTle >>its a killer with 2 monitors .
i connected a tele..lenco 21" pal and its basicly **** : cant read anything , if i want to understand whats going on i need to switch to 640x480 very small indeed .... do you know if its a matter "selecting the right tele " ? what is the best tele to connect ? the max hz i have when a tele is connected it 60HZ on ntsc and 50hz on pal ... does studio monitor will be allways better then a tele ? thanks ---------------------- sandman
Oh, it gives off an orange cloud of light, that just flows right out over the sea... wow! |
I bought a Promax DH max ( I think) and found that I couldn't use it with two 21" monitors at the resolution I'm used to: 1600x1280. Only one monitor will go that high. The other maxes out too low (can't remember what res.) I returned it and bought a Jeronimo 2000. Works great!
G4 450 DP, Magma exp chassis, Mix3, etc. Also works with another system I installed: G4 450, Mix2 |
Thanks for the info.
EMI Noise: Graphics card to HD Native card | jacknprewitt | Pro Tools HDX & HD Native Systems (Mac) | 0 | 10-19-2013 09:02 PM |
HD Native Card Possibly Fried My Graphics Card | witrelo | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-14-2011 11:46 AM |
Graphics card for G4 800 gone bad | MidnightFlyer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2007 07:43 PM |
What graphics card are you using? | Calvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-29-2004 10:00 AM |
Which Graphics Card for 2 LCD use? | timcissell | Pro Tools TDM Systems (Mac) | 2 | 07-25-2002 07:38 AM |
