Old 08-09-2004, 10:05 AM
Mount Royal Mount Royal is offline
Default Advice: MIx3 PT 5.1 to PT Upgrade
I'm needing help with the upgrade to PT6 process for a Mix++ system running within OS9.2.2. After doing a DUC Search and consulting Compatibility, I'm left with a few questions concerning my specifics, if you would please...
1) Hardware list:
G4 933 single processor
Mix Core, Farm x2
ADAT Bridge (Lucid 8824 interface x2)
Digi 888
RME Nanosyncs clock
Promax dual VGA card (multiple monitor pairs @ 1024 off VGA splitters)
Motu MIDI Timepiece USB interface (Yamaha S80, Roland XV-5080)
The goal is to operate the above within Panther, yet to be installed on the G4 933 machine. Do I have hope? Will the Promax card work? I'd like to carryover Reverb One and Analog Channel plugs, but don't understand the upgrade process here. Will Waves Platinum Bundle operate in this envorinment? Any chance of getting the latest revision Core Audio Driver to work here?
My apologies for the shot gun discharge of questions. It's scary having such an old system and having been away from the DUC for a while.
Many thanks,
John Caldwell
Pro Tools 2018.4
HDX, 192 and Lucid I/O
5,1 MacPro 12 Core; OSX 10.12.6
Old 08-09-2004, 04:44 PM
Default Re: Advice: MIx3 PT 5.1 to PT Upgrade
Your system is not that old. The computer is only 2 years old, and will certainly run Panther. Heck, the G3/500 I'm using to type this post runs Panther! However, to use Panther with your MIX system, you must wait for the v6.4.1 PT software, which Digi said would be released this summer.
You'll have to check with Promax to see if their card works with OS X.
The MOTU interface will work with OS X.
You'll have to check with the plug-in manufacturer's about compatibility, but I would be shocked if ReverbOne didn't work in OS X. I don't use Platinum, but Gold v4 works in OS X fine. If your farm cards are DSP Farm cards, WAVES makes no guarantee that Platinum v5 works with those cards. If your farm cards are MIX Farm cards, then you should be golden.
Budget at least a day for your upgrade. Good luck!
Old 08-10-2004, 05:40 AM
Thank you, Chief. Do you believe Pro Tools will recognize the Promax video card so long as the card works in OSX? In the past Pro Tools was very particular about dual VGA display video cards. Lastly, what about the Core Audio Driver and Mix system (Core = Farm Card x2)? Can it work?
Thanks for your insights.
John Caldwell
Pro Tools 2018.4
Old 08-10-2004, 06:06 AM
Vaphoron Vaphoron is offline
There will be a new Core Audio driver when 6.4.1 is released for MIX systems and that should work great for you. Unfortunately your video card will not work. If you are in need of a new video card for OSX that is supported, I am selling my ATI Radeon 8500 Mac Edition for $125 with shipping. If you want the details, you can just send me an email to the address in my profile. Check out this link for some compatibility info for moving from OS9 to OSX.
http://www.digidesign.com/compato/osx/new.cfm
- Jason
Old 08-10-2004, 06:18 AM
Thank you Jason. Is the card you offer an AGP card with dual VGA outputs, along the lines of Promax or Appian Jeronimo? Is there reason to believe that your card will operate with the forthcoming PT 6.4.1 within Panther? I do see that the Promax will not work in the Compat section you referenced above.
Thank you.
John-
Pro Tools 2018.4
Old 08-10-2004, 08:13 AM
The Radeon 8500 is an AGP graphics card with dual VGA outs. I used the card in Panther with a MixPlus system running PT 6.2.3 so it should work great with the new version also. I am selling it because I am moving up to a G5 really soon.
- Jason
PT 10.3.4 upgrade advice guitarman6 macOS 4 06-24-2013 10:02 AM
Upgrade to 7? Need advice Mitai 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-08-2006 11:04 AM
Mix3 upgrade to HD2 accel = How much more Power ? WRipley Pro Tools TDM Systems (Mac) 7 06-25-2005 03:02 PM
Upgrade From Mix3 to HD2 why not? Dutchmuzik Pro Tools TDM Systems (Mac) 7 01-20-2002 03:46 AM
Need Upgrade Advice marsdomain General Discussion 0 07-05-2001 06:55 AM
