Quicktime files compability with PT 7.3 LE without DV tk2
I have imported some QT-files into PT-sessions without problems.
A friend of mine works with Avid but when I try to import his files, PT crashes. Is Digitranslator needed for this? Thank you |
Re: Quicktime files compability with PT 7.3 LE without DV tk2
What kind of files?
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
If the movie file is PAL 25 fps, DV Toolkit shouldn't have any bearing on this.
Do you have QT Pro? If so, just export via that as another codec type and see if that fixes the problem... If not, post back. |
I have quicktime Pro
I had not problems with the digidesign QT-files, packed with the 101 course. |
It´s very difficult to help you if you don´t provide the info about what kind of QT-codec is causing the issue. QT is just a container-format for a huge amount of different codecs.
PT should play most of them but some are not recommended. Open the QT in question in the QT-player (not PT) and hit apple-i. The window will give you the info what actual format your QT is. If you have an un-supported QT you can transcode it with QTpro. These shouldn´t cause any issues: DV MJPEG Frank.
If your editor is outputing files in AVID codecs, such as the AVID DV codec or one of their other codecs, you won't be able to do much with the files even in QT PRO. You can check the codec by opening the movie in QT and choosing "Get Movie Info". If it shows up as AVID DV or another AVID codec, you can go here and download the Avid codecs. You should then be able to re-encode the movie for your use. Even with the codecs installed the movie may not play well in ProTools so you should re-encode.
"Ya canna change the laws of physics..." -Montgomery Scott Howard Sonnenburg Atomic Audio Ottawa, ON Canada |
Thanks, since downloading and installing the AVID codecs, everything works fine!
Thank you all very much! Cyril John The Netherlands |
Good to hear.
Take it easy, Phil J. |
Compability? - PT HD 10 &11 with OSX 10.8.5? | Shame | Pro Tools 11 | 5 | 11-11-2013 01:30 AM |
Logic 7.2.3 TDM compability | oscarwonderboy | Pro Tools TDM Systems (Mac) | 2 | 03-01-2010 08:59 AM |
mpd compability | Noctune | Pro Tools M-Powered (Mac) | 3 | 03-12-2009 05:30 PM |
Mac/PC-compability - why that way? | Ploch Klaus | Pro Tools TDM Systems (Mac) | 0 | 06-01-2004 04:00 AM |
Compability - plug-ins and PT 5.0 | srm | Pro Tools TDM Systems (Mac) | 2 | 08-24-2000 09:18 AM |
