8.0.3 update not working so well
Hi, there. everything seemed to work very well (apart from EZ player on a mac) with PT LE 8.0.1 but the recent 8.0.3 update messes up with my Addictive Drums (the latest version) , it keeps crashing so bad. EZ player still crashes, too. Toontrack stuff is so unstable on PT (Mac system). Ez player works alright on Logic but on my PT it crashes like nobody's business.. i contacted them but they blamed on Digi.. aww
Re: 8.0.3 update not working so well
A bit more detail about your system would be good.
What troubleshooting steps have you gone through?
my blog:Tamas Dragon |
Can't speak of addictive drums but EZDrummer and Superior Drummer are working on my set up with no problems.
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
The thing is, everything works fine with 8.0.1, i actually went back to it again and now everything works (not Ez player pro, it has probs with AD, but with BFD it works). i think 8.0.3 is not yet compatible with some plugs/samplers? well, vice versa. |
Hi, need more detail. First off I use EZ a lot in all my sessions. Usually after rendering a snare or kick in Drum Tracker just to sure-up a snare or kick sound.
I've been using EZ from 7.4 to 8.0,cs1 and 2 and now 8.03 with no issues. I'm mixing a session that started on 7.4 HD, then to 8.0.1cs2 LE with EZ, upgraded to 8.0.3 and the session is working fine. Have you trashed your prefs??? Have you read any of the Tech Sup doc's in the sticky section? "Help us help you"?
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
Toontrack blames on Addictive Drums and Digi.. im telling them there are bugs with EZ player Pro on PT. it crashes with AD and the latest update does not have SSD 3.5 on PT even theres a correct mapping on Logic. BFD works fine with EZP, and Logic is fine with EZplayer too. just PT is not liking EZ player pro. its just tested by Toontrack properly, they shouldnt really advertise their software when they havent fully tested with all the DAWs and Drum samplers. Paul, can you see a mapping (in MapWrap) for Steven Slate Drums 3.5 (SSD 3.5), in you EZ player Pro? the latest update (1.0.5) is supposed to have SSD 3.5 but theres only 3.0 maps. my version is the correct version, on the logo it shows 1.0.5. EZ player stops functioning when Addictive Drums is there, tried and tested. AD and SSD works perfectly on their own in PT but when EZplayer pro comes in, everything doenst work. it crashes or freezes. while BFD works well there... |
HD is working, should I update? | perryr | Pro Tools HDX & HD Native Systems (Mac) | 6 | 06-04-2012 08:24 PM |
Update 9.0.5. NOT Working | MiguelAlba | macOS | 6 | 08-25-2011 02:08 PM |
Update 2.6 for MC-Mix not working right | SB MIX | Artist Series | 7 | 06-25-2011 08:30 AM |
8.01 update not working | barters81 | Pro Tools M-Powered (Mac) | 2 | 12-31-2009 03:24 PM |
PC update not working! | johnnyv | ProControl, Control|24, Command|8 | 4 | 01-30-2002 08:39 AM |
