Core Audio Driver with multi-channel output?
I would like to playback 5-6 channel Quicktime streams through the Digi hardware on an HD and 002 system (Mac). When assigning the Digi hardware to AMS in both cases only 2 channels of output show. Is there an available multi-channel output driver somewhere that I can use to run multiple outputs from a non DAW program? The M-Powered systems work great. This is only a digi driver issue.
Thanks
Gadgets can make the music better, but the pursuit of gadgets is killing music. |
Re: Core Audio Driver with multi-channel output?
Unfortunately, there isn't a multi-channel Core Audio driver available for Digidesign hardware.
NI Battery 2.1 and multi-channel output | JackV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-23-2005 12:52 PM |
Multi Channel Core Audio | mnoxious | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 06-11-2004 05:33 PM |
Multi-channel output | String of Child | General Discussion | 4 | 11-18-2003 05:06 PM |
will digi 001 core audio driver ever be multi-client? | apoch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-05-2003 07:07 AM |
001 core audio driver only allows 1 channel 32 bit linear I/O | joshua h | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2003 07:34 PM |
