Old 01-17-2001, 02:41 PM
Dopamine Dopamine is offline
Default \"program error\"
We just added a single ProControl to our g4-based PT setup and are now getting crashes that say there is a "program error". Any advice in fixing this is most appreciated.
http://www.phuturetrax.com
Old 01-18-2001, 08:25 AM
DigiTechSupt's Avatar
Default Re: \"program error\"
Dopamine
With the limited information you have provided I can only suggest the following:
1)Make sure you are using the Red labeled ethernet crossover cable for the Procontrol.
2)Make sure you have not altered the minimum
memory configurations in Pro tools and DAE.
3)If you disconnect the Procontrol does Pro tools function properly?
4)Did you add any third party software to your system about the same time you added Procontrol?
5)If the answer to #3 is no, try trashing the
Digi system init and Pro tools application
and re-install them from the CD.
MJ
Digidesign tech support
Avid Audio Tech Support
Support FAQ
A program error occured???.. isiklar Windows 3 03-17-2011 12:30 AM
Program Error? eastnwest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-22-2005 09:09 PM
fatal program error musicmixer04 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 10-09-2004 11:12 AM
Program Error (-9060) sonmi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-01-2003 08:51 PM
Program Error-what is it Rob Daly Pro Tools TDM Systems (Mac) 2 02-28-2000 08:57 PM
