Old 03-26-2008, 08:02 AM
Alex Stolichnya Alex Stolichnya is offline
Default Structure Free no longer recording to inst trk
I asked this question in another forum, but that might not have been the correct venue. I've installed Structure Free on my iMac running Pro tools m-powered 7.4. when I first installed the software I set up an instrument track and popped in the Structure Free plug in. I armed the track and started the recording. the midi dashes were appearing as expected, and it played back the drum samples I recorded with no problems. I was using the software keyboard to noodle around as I didn't have any outboard midi interfaces hooked up at the time. I was liking this so I decided to try it a second time. Once again, I set up an instrument track, armed it and started recording. This time nothing. The midi values aren't being recording to the track no matter what I do. I can use the pencil tool and draw midi "notes" but I can't record them real-time. I can't figure out what I've screwed up here. The midi notes that I draw will play back what ever patch I've got loaded in Structure, no problem. I haven't hooked up an outboard interface, (my m-audio Axiom 49 for example), so I don't no if this is a problem with the midi settings overall. This is really perplexing to me. Has anyone else had this issue? This is the only Instrument plug in I've got for my system at this point so I don't know if other plug-in's will behave the same way.
Any help would be greatly appreciated.
Old 03-26-2008, 07:08 PM
Default Re: Structure Free no longer recording to inst trk
I'd set it up to rule it out.
filosofem
Aaron Mulqueen - 001 HD Native
When I loaded Structure from VIRT pack, Structure Free menu still there. dl0banter Virtual Instruments 2 06-12-2011 02:23 AM
Inst. exp. pack installed, Structure Free still here Joshua3189 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-05-2011 06:53 PM
Importing Garritan Inst. for Finale into Structure jerosta Virtual Instruments 0 03-18-2009 07:30 PM
Structure Free instrument plug-in not recording on track. Alex Stolichnya Pro Tools M-Powered (Mac) 3 03-26-2008 07:24 AM
Recording Virt Inst midi notes bblue Virtual Instruments 3 01-19-2008 05:47 AM
