Old 10-02-2006, 04:49 AM
tonzauber tonzauber is offline
Default Mixdown recording to track
Hi, forgive me I'm a Protools novice, and just got my digi002.
I've got the following problem:
I do a mixdown and route the individual tracks to busses. Then I add another audio track and set a bus as input for this audio track, and analogue 1&2 as output. I record enable this track and play back my other tracks, but I can't hear anything and also the meters are not moving (so obviously no signal arrives there)
But when I enter record, everything works fine as expected.
I am working with PT LE7.0, and tried the above things on PT LE6.9 on a colleague's setup, where it works fine.
Has this been changed between the versions? I'm a bit confused because I dont know how to adjust the mixdown if I can only hear things during record....
Any ideas what may be the culprit?
Thanks
Georg
Old 10-02-2006, 06:57 AM
wheresmyfroggy wheresmyfroggy is offline
Default Re: Mixdown recording to track
You need to set your record mode to 'input only' instead of 'auto input', this should be in your options menu. Sorry i am being a bit vague but am on HD now and it is different so am having to remember.
HTH
Tom
Old 10-03-2006, 03:05 AM
arneal arneal is offline
Hey Georg,
The keyboard shortcut (on a Mac) is option + k to switch to 'input only'.
21.5" (Late-2015) 11,2 iMac i5 2.8GHz, 16Gb, PT 12.8.2, Metric-Halo ULN2 2d Exp'd w/Sierra 10.12.6
Can't assign audio to new track for mixdown LSJ Pro Tools TDM Systems (Mac) 1 02-09-2011 06:29 PM
Disappearing Track in Mixdown raiderrob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-07-2010 03:00 PM
Plugins on a mixdown track paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-27-2008 09:31 PM
Plugins on Master Fader or Main Mixdown Track studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-20-2007 12:02 PM
Recording MIDI input during mixdown viewstart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-20-2005 03:07 AM
