What is variable stereo pan depth?
In PT 9?
Re: What is variable stereo pan depth?
Go change the pan depth , pan a track and you'll hear what it does...
This is explained in the PT 9 documentation (IIRC in the What's new document).
It controls the level of the channels at center pan. -6 dB of left and right give you mono compatibility (same signal on left and right) (no increase in level as the pan moves through center). But for less well correlated signals from left and right, this can cause a dip in loudness, so other curves are used where the center level of each channel is reduced less: -4.5 or even only -3 dB.
Kevin Windrem Sweet Spot Sound |
What was the pan depth in previous versions? (I'm guessing -6 dB)
I just tried a quick google search looking for the set pan depths in different DAWs but got nothing... What is it in Logic? Nuendo? |
Maybe people should read the what's new document before posting.
I'll go read the "what's new document" |
You might check out this basic explanation of pan depth (or Law). It's referring to Logic but the principles are the same:
http://logicquicktips.blogspot.com/2...ws-of-pan.html And here's further discussion which gives even more info: http://www.logicprohelp.com/viewtopic.php?p=271593 |
Pan Depth setting not working on stereo sub-busses | Zarabozo | Windows | 1 | 12-11-2012 09:52 AM |
Variable Aux | ickymix | VENUE Live Sound Systems | 1 | 12-01-2010 07:41 AM |
Using Variable Groups | ickymix | General Discussion | 1 | 11-19-2010 08:32 AM |
variable speed? | PYT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-02-2003 11:02 AM |
maley variable mu | taichber | Tips & Tricks | 3 | 05-21-2003 09:22 PM |
